Thanks Frank, however I removed the reference to the tlb's and just
referenced the Autodesk.AutoCAD.Interop.dll and
Autodesk.AutoCAD.Interop.Common.dll directly and I get 91 errors in my
build. All say I'm missing a namespace called 'RxClass'.
c:\Documents and Settings\TJRiley\My Documents\SharpDevelop
Projects\snoop\SnoopClassesCompForm.cs(219,16): error CS0246: The type or
namespace name 'RXClass' could not be found (are you missing a using
directive or an assembly reference?)
Build complete -- 91 errors, 0 warnings
I'm new to C# as well as .net and I'm just trying to look at some samples to
get an idea of what's going on. Any help is greatly appreciated.
~Tim Riley
"Frank Oquendo" wrote in message
news:414f2219$1_3@newsprd01...
> Tim Riley wrote:
> > fatal error CS0009: Metadata file 'c:\Program Files\Common
Files\Autodesk
> > Shared\acax16enu.tlb' could not be opened -- 'There isn't metadata in
the
> > memory or stream'
> Those type libraries are not .NET assemblies.
> If referencing the TLB files does not automatically result in a
> reference to Autodesk.AutoCAD.Interop. dll and
> Autodesk.AutoCAD.Interop.Common.dll, remove the references.
> Next, open the References dialog and browse using the GAC tab. You
> should see the above named assemblies in that list. Those are the proper
> references.
> There are 10 kinds of people: those who understand binary and those who
> don't.
