I 've created palettes to share with other users. I can use AutoCAD options to declare where I save the palettes, and tell all users to modify AutoCAD options to use this directory. So, if I modify or add palettes, when you launch AutoCAD you automatically load the palettes in this directory, This is very parctical to automatically update palettes on users workstations, but this mean ALL the palettes are loaded !
What I try to do is to have a directory containing all the palettes (xtp files), where users can choose those they whish to use. If this directory is modified (add or modify xtp files), when you start AutoCAD your palettes are updated. But only the palettes you use on your own computer, without requiring you to load all the palettes in the directory.
Any idea ?
