ha
Guess I answered my own question!
ThisDrawing.Application.Update
seems to work, now if they would just fix the DWF 6 so it is unnecessary!
Shawn Romkey P.Geo
Noranda Mining
"Shawn Romkey" wrote in message
news:F7137E1A681254CC81D292B42552AB7D@in.WebX.maYIadrTaRb...
> Some further info
> It appears the code does work but only if you save the drawing and then
> reenter it, at that point the hide property is set to yes. Anyway of
> forcing the update immediately without leaving the drawing?
> AHGA
> Shawn Romkey P.Geo
> Noranda Mining
> news:1B8B6C9E994388200983AA087E372555@in.WebX.maYIadrTaRb...
> > To all
> > I have found a bug in the new Expressviewer that is a little irratiating
> and
> > have to work around it with some programming. Basically the bug is when
a
> > view port in paperspace has the hide property set to no then if the view
> is
> > clipped objects show through the clip on the DWF file (if you plot from
> CAD
> > they are OK, only show up in the DWF file). So.. I have to redefine the
> > publish command to set all the viewports to hide = yes
> > Below is the code but for some reason it doesn't change the hide option
on
> > the property, any idea's why?
> > ' code from Acadx.com to make selectionset
> > Public Function CreateSelectionSet(Optional ssName As String = "ss") As
> > AcadSelectionSet
> > Dim ss As AcadSelectionSet
> > On Error Resume Next
> > Set ss = ThisDrawing.SelectionSets(ssName)
> > If Err Then Set ss = ThisDrawing.SelectionSets.Add(ssName)
> > ss.Clear
> > Set CreateSelectionSet = ss
> > End Function
> > Sub test()
> > Dim fType(0 To 1) As Integer, fData(0 To 1)
> > Dim index As Long, i As Long
> > Dim ent As AcadEntity
> > Set ss = CreateSelectionSet
> > fType(0) = 67: fData(0) = 1
> > fType(1) = 0: fData(1) = "VIEWPORT"
> > ss.Select acSelectionSetAll, , , fType, fData
> > If ss.Count = 0 Then
> > Set ss = Nothing
> > Else
> > For i = 0 To ss.Count - 1
> > Set ent = ss(i)
> > ent.RemoveHiddenLines = True
> > ent.Update ' tried this to see if it would work
> > Next
> > End If
> > End Sub
> > AHGA
> > Shawn Romkey P.Geo
> > Noranda Mining
