VBA
Discuss AutoCAD ActiveX and VBA (Visual Basic for Applications) questions here.
Sendcommand
2 REPLIES 2
161 Views, 2 Replies
Sendcommand
I am writing a program in AutoCAD 2000.
The program must change UCS a number of times referring to some blocks insert in 3D.
To change USC I use the following code
Public Function ChangeUcs (ObjHand As String) As Boolean
Dim Command As String
Command = "Ucs" & vbCr & "ob" & vbCr & "(HANDENT " & Chr(34) & ObjHand & Chr(34) & ") "
ThisDrawing.SendCommand Command
ChangeUcs = True
End Function
My problem is the following:
The program runs perfect when started from the VBA editor, but it will not run called direct from AutoCAD.
I seams, as the "sendcommand" is not executed before the program is ended.
I use the "sendcommand" I other variations without problems, so I assume it is the UCS operation that fails.
Can anyone give me a tip on how to run the code from AutoCAD?
2 REPLIES 2
Sub Example_UCSIconAtOrigin()
' This example toggles the setting of UCSIconAtOrigin.
    Dim viewportObj As
AcadViewport
    ' Set the viewportObj
variable to the activeviewport
    Set viewportObj =
ThisDrawing.ActiveViewport
    ' Make
sure the UCS Icon is on, and a new UCS is defined.
    ' The
new UCS defines the origin for the icon. When the icon
is not displayed at the origin, it is displayed at the
lower-left corner of the display.
    Dim ucsObj As
AcadUCS
    Dim origin(0 To 2) As Double
Dim xAxisPoint(0 To 2) As Double
    Dim yAxisPoint(0 To 2) As
Double
    origin(0) = 2: origin(1) = 2: origin(2) =
0
    xAxisPoint(0) = 3: xAxisPoint(1) = 2: xAxisPoint(2) =
0
    yAxisPoint(0) = 2: yAxisPoint(1) = 3: yAxisPoint(2) =
0
    Set ucsObj =
ThisDrawing.UserCoordinateSystems.Add(origin, xAxisPoint, yAxisPoint,
"UCS1")
    ThisDrawing.ActiveUCS =
ucsObj
    viewportObj.UCSIconOn = True
    ' Display the current setting of
UCSIconAtOrigin
    MsgBox "UCSIconAtOrigin is: " &
IIf(viewportObj.UCSIconAtOrigin, "On", "Off"), , "UCSIconAtOrigin
Example"
    ' Toggle the setting of
UCSIconAtOrigin
    viewportObj.UCSIconAtOrigin = Not
(viewportObj.UCSIconAtOrigin)
Reset the active viewport to see the change
ThisDrawing.ActiveViewport = viewportObj
    MsgBox "UCSIconAtOrigin is now: " &
Example"
End Sub
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
I
insert in 3D.
Dim Command As
String
Command
ChangeUcs = True
End Function
AutoCAD?
I have tried this way but in my case I have to calculate the x-Axis and y-axis from the Block properties.
I am not a mathematic genius, and my Knowles of vector mathematic is poor, so a friend of my have produced some program code that should do the calculation, BUT the algorithm is not reliable some time the UCS is turned upside down, and some time the x- and y-Axis is not the one AutoCAD find by using the USC OB command.
That’s why I try “sendcommand”, and as I write from the VBA editor I works nice, but not from AutoCAD.
If anyone can give an example of how to calculate the x- and y-Axis, from the data in the block properties that would be nice.
”Boost
