SelectOnScreen VBA
SelectOnScreen VBA
Message 1 of 8
SelectOnScreen VBA
with VBA i use the SelectOnScreen method
Is it possible to know the two points clicked if the user select with "window"
or "crossing"?
Thank you
Bernard Flavignard
Replies (7)
Message 2 of 8
Hi Bernard
Load the code from this link:
http://www.apress.com/book/supplementDownload.html?bID=242&sID=1577
Fatty
~'J'~
Message 3 of 8
Thank Fatty,
I found this
Public Sub TestSelectOnScreen()
Dim objSS As AcadSelectionSet
On Error GoTo Done
With ThisDrawing.Utility
'' create a new selectionset
Set objSS = ThisDrawing.SelectionSets.Add("TestSelectOnScreen")
'' let user select entities interactively
objSS.SelectOnScreen
Here i want to know the 2 points clicked if user choose Windows or crossing by
clicking only a rectangle
'' highlight the selected entities
objSS.Highlight True
'' pause for the user
.Prompt vbCr & objSS.Count & " entities selected"
.GetString False, vbLf & "Enter to continue "
'' dehighlight the entities
objSS.Highlight False
End With
Done:
'' if the selection was created, delete it
If Not objSS Is Nothing Then
objSS.Delete
End Sub
Bernard Flavignard
a écrit dans le message de news: 5147727@discussion.autodesk.com...
Hi Bernard
Fatty
~'J'~
Message 4 of 8
Happy to help
Cheers 🙂
Fatty
~'J'~
Message 5 of 8
I am French, and i dont understand all you say in english....
My question in the code.... i have the book.
Bernard Flavignard
a écrit dans le message de news: 5147862@discussion.autodesk.com...
Happy to help
Cheers 🙂
Fatty
~'J'~
Message 6 of 8
Hi Bernard,
Sorry for my inattention...
I shall help you tomorrow, now is too later for me
Btw, I am from Russia
Have a good one
~'J'~
Message 7 of 8
Okay, see this example but very quick and dirty...
[code]
Sub Example_SelectBy_Window()
' This example adds members to a selection set by window
Dim objnewss As AcadSelectionSet
Dim objSelColl As AcadSelectionSets
Dim fstCorner, sndCorner As Variant
With ThisDrawing
Set objSelColl = .SelectionSets
For Each objnewss In objSelColl
If objnewss.Name = "$TestSset$" Then
objSelColl.Item("$TestSset$").Delete
Exit For
Next objnewss
Set objnewss = objSelColl.Add("$TestSset$")
fstCorner = .Utility.GetPoint(, "Enter first corner of window")
sndCorner = .Utility.GetCorner(fstCorner, "Enter opposite corner of window")
Dim mode As Integer
mode = acSelectionSetWindow
' another mode you can use:
'acSelectionSetCrossing
objnewss.Select mode, fstCorner, sndCorner
objnewss.Highlight True
.Utility.Prompt vbCr & objnewss.Count & " entities selected"
.Utility.GetString False, vbLf & "Enter to continue "
objnewss.Highlight False
End With
MsgBox ("First corner : " & vbCrLf & _
"X: " & CStr(fstCorner(0)) & vbCr & _
"Y: " & CStr(fstCorner(1)) & vbCr & _
"Z: " & CStr(fstCorner(2)))
MsgBox ("Second corner : " & vbCrLf & _
"X: " & CStr(sndCorner(0)) & vbCr & _
"Y: " & CStr(sndCorner(1)) & vbCr & _
"Z: " & CStr(sndCorner(2)))
End Sub
Fatty
~'J'~
[/code] Message was edited by: Fatty
Message 8 of 8
Fatty,
Excuse me, but it is not what i want.
I want to program only
clicking only a rectangle, not choose W ot C
I do not want
Sorry
Bernard Flavignard
a écrit dans le message de news: 5148003@discussion.autodesk.com...
[code]
With ThisDrawing
Exit For
Next objnewss
Dim mode As Integer
End With
End Sub
Fatty
~'J'~
[/code]
