Hello Jeff Mishler,
Thanks for your reply.After scale i have to extract data to excel sheet.if i didnt do scale, data didnt export.if i do with scale coding,after that i cant able to export.so i try to use send command.while using send command by manually in autocad, i am able to export data to excel sheet.thats why am using send command.I dont know where I did mistake.for extracting data i am using selection set points.
for ex:(below points are after scaling)
Set oSset = adoc.SelectionSets.Add(setName)
Dim p1(2) As Double
p1(0) = 11: p1(1) = 21: p1(2) = 0#
Dim p2(2) As Double
p2(0) = 155: p2(1) = 77: p2(2) = 0#
oSset.Select acSelectionSetWindow, p1, p2, dxfcode, dxfdata
Thanks again,
bharathi
