• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Visual Basic Customization
    Distinguished Contributor
    Reverse Polyline - With Bulges - Last Bulge Problem
    249 Views, 4 Replies
    10-15-2008 02:57 PM
    Ok, I'm writing a VBA to reverse the direction of a closed polyline, with bulges. I've pulled code from this forum (Thank yall very much) and it seems to be working except where the last point joins the first. If there is a bulge between the last point and the first point, it doesn't seem to register, and when the reversal is finished, the last bulge is reversed.
    Is there a trick to getting and/or setting the bulge between the last and first points of a closed polyline? If I get the bulge from the last point, it says Zero, even though it's rounded.
    I'm at the end of my day here, so I can't post code right now, but I'll toss it in here tomorrow.
    Thanks.
    Please use plain text.
    Re: Reverse Polyline - With Bulges - Last Bulge Problem
    10-16-2008 06:23 AM in reply to: StevieLee
    Uh oh, no responses yet. Hope someone can help me figure this out.
    As an example, draw a rectangle using RECTANG, then use FILLET to round off the corners. That'll be the GuineaPig. Here's the code I got from this forum. I forgot the name, but thank you very much.
    Private Sub ReversePline(plineObj As AcadEntity)
    Dim pts() As Double
    Dim bulge() As Double
    Dim legs As Integer
    Dim retcoord As Variant
    Dim i As Integer
    Dim i2 As Integer
    Dim FN As Long
    '--- I added some code to write bulges to a text file so I can see what its doing ---
    FN = FreeFile
    Open "C:\bulge.txt" For Output As #FN
    retcoord = plineObj.Coordinates
    ReDim Preserve pts(UBound(retcoord))
    legs = (UBound(retcoord) / 2) - 1
    ReDim Preserve bulge(legs)
    For i = legs To 0 Step -1
    Print #FN, i & " = " & CStr(plineObj.GetBulge(legs - i))
    bulge(i) = plineObj.GetBulge(legs - i) * -1
    Next i
    For i = UBound(retcoord) To 0 Step -2
    i2 = UBound(retcoord) - i
    pts(i2 + 1) = retcoord(i)
    pts(i2) = retcoord(i - 1)
    Next i
    plineObj.Coordinates = pts
    For i = 0 To legs
    plineObj.SetBulge i, bulge(i)
    Next i
    Close #FN
    End Sub
    10-16-2008 08:23 AM in reply to: StevieLee
    Eureka! (eeka...eeka) I figgered it out.
    I went back and applied a little brute force tactics, making OLDX and OLDY then swapping NEWX and NEWY, etc. Not very elegant, but "Life is pain. Get used to it." (Name that movie.)
    Anyway, it worked, and I'll post it below for anyone who's interested.
    Dim pts() As Double
    Dim OLDptX() As Double
    Dim OLDptY() As Double
    Dim NEWptX() As Double
    Dim NEWptY() As Double
    Dim legs As Integer
    Dim i As Integer
    Dim iOLD As Integer
    Dim iNEW As Integer
    legs = ((UBound(retcoord) + 1) / 2) - 1
    ReDim Preserve OLDptX(legs)
    ReDim Preserve OLDptY(legs)
    ReDim Preserve NEWptX(legs)
    ReDim Preserve NEWptY(legs)
    '\\\Establish Points Array from PolyLine Coords
    For i = 0 To UBound(retcoord)
    pts(i) = retcoord(i)
    Next i
    '\\\Keep PointZero the same and Reverse Remaining Points
    '\\\Brute Force Method (Ugh *scratch scratch*)
    iNEW = legs
    For iOLD = 1 To legs
    OLDptX(iOLD) = pts(iOLD * 2)
    OLDptY(iOLD) = pts((iOLD * 2) + 1)
    NEWptX(iNEW) = OLDptX(iOLD)
    NEWptY(iNEW) = OLDptY(iOLD)
    iNEW = iNEW - 1
    Next iOLD
    '\\\NOTE-New Points Gathered, but Not Applied Yet
    '\\\Get Bulges in Reverse Order and Make Them Negative
    For i = 0 To legs
    Next i
    '\\\Reverse All Points Except PointZero (Apply New Points)
    For i = 1 To legs
    pts(i * 2) = NEWptX(i)
    pts((i * 2) + 1) = NEWptY(i)
    Next i
    '\\\Give New Points to PolyLine
    '\\\Set New Bulges
    For i = 0 To legs
    Next i
    plineObj.Update
    End Sub
    *MP
    10-16-2008 08:58 AM in reply to: StevieLee
    another option
    just changed your indexes slightly
    seems to work
    AcadEntity)
    Dim pts() As Double
    Dim legs As
    Integer
    Dim i As Integer
    Dim i2 As
    Integer
    Dim FN As Long
    FN = FreeFile
    Output As #FN
    ReDim Preserve
    'changed legs calc
    'changed index
    For i = legs To 1 Step -1
    'Print #FN, i & " = " &
    CStr(plineObj.GetBulge(i - 1))
    'bulge(i) = plineObj.GetBulge(legs - i) *
    -1
    bulge(i - 1) = plineObj.GetBulge(i - 1) * -1
    Next i
    i2 =
    1)
    Next i
    'changed index
    For i = 0 To legs - 1
    Print #FN, i
    & " = " & CStr(plineObj.GetBulge(i))
    Next i
    Close #FN
    End
    Sub
    hth
    mark
    style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
    Eureka!
    Anyway,
    snip
    New Member
    02-01-2013 10:58 AM in reply to: StevieLee
    Public Sub ReversePolyline()
    Dim NewCoords() As Double
    Dim Bulge() As Double
    Dim Segm() As Double
    Dim Bul As Double
    Dim OldCoords As Variant
    Dim Entity As AcadEntity
    Dim legs As Integer
    Dim I As Integer
    Dim J As Integer
    Dim N As Integer
    OldCoords = plineObj.Coordinates
    ReDim NewCoords(LBound(OldCoords) To UBound(OldCoords)) As Double
    J = LBound(NewCoords)
    For I = UBound(OldCoords) To LBound(OldCoords) + 1 Step -2
    NewCoords(J) = OldCoords(I - 1)
    NewCoords(J + 1) = OldCoords(I)
    J = J + 2
    Next I
    N = 0
    For I = LBound(OldCoords) To UBound(OldCoords) - 2 Step 2
    Bul = plineObj.GetBulge(I / 2)
    N = N + 1
    ReDim Preserve Bulge(N)
    ReDim Preserve Segm(N)
    Bulge(N) = Bul * -1
    Segm(N - 1) = (I / 2)
    Next I
    Segm(N) = N
    plineObj.SetBulge Segm(I / 2), 0
    Next I
    For I = 0 To N - 1
    plineObj.SetBulge Segm(I + 1) - 1, Bulge(N - I)
    Next I
    plineObj.SetBulge Segm(N), Bulge(1)
    plineObj.Coordinates = NewCoords
    plineObj.Update
    End Sub
