VBA
Discuss AutoCAD ActiveX and VBA (Visual Basic for Applications) questions here.
Return attributes of blocks in XRef
7 REPLIES 7
Message 1 of 8
hakand
1512 Views, 7 Replies
Hey guys,
Just wondering how I would return attributes of blocks in my drawing's XRefs?
I've come across one example that is in VB but doesn't really help me much.
I currently have a list in a form that consists of all the XRefs in my drawing and I wish to return all blocks and attributes that are linked to the selected XRef.
Many Thanks!
HD
7 REPLIES 7
Message 2 of 8
Alfred.NESWADBA
in reply to: hakand
check this
Public Sub listAttRefInXRef()
   Dim tBl As AcadBlock
   For Each tBl In ThisDrawing.Blocks
      If tBl.IsXRef Then
         'ok, we got a XRef, now scan it's modelspace for BlockReferences
         Dim tEnt As AcadEntity
         For Each tEnt In tBl.XRefDatabase.ModelSpace
            If TypeOf tEnt Is AcadBlockReference Then
               Dim tBlRef As AcadBlockReference
               Set tBlRef = tEnt
               If tBlRef.HasAttributes Then
                  'BlockReference has AttributeReferences
                  Dim tAtts As Variant
                  Dim i As Integer
                  tAtts = tBlRef.GetAttributes
                  For i = LBound(tAtts) To UBound(tAtts)
                     'output each AttributeReference
                     Debug.Print tBlRef.Handle & " " & tAtts(i).TagString & ": " & tAtts(i).TextString
                  Next
               End If
            End If
         Next
      End If
   Next
End Sub
HTH, - alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
Message 3 of 8
hakand
in reply to: Alfred.NESWADBA
Thanks for your response Alfred!
Im sorry but I forgot to mention that I would be trying to achieve this in VB.net
This is what I currently have going but am stuck at a roadblock:
        Dim ed As Editor = Application.DocumentManager.MdiActiveDocument.Editor
        Dim doc As Document = Application.DocumentManager.MdiActiveDocument
        Dim db As Database = HostApplicationServices.WorkingDatabase
        Dim tr As Transaction = db.TransactionManager.StartTransaction()
        Dim res As PromptSelectionResult = ed.SelectAll
        Dim selSet As SelectionSet = res.Value
        Dim idArray As ObjectId() = selSet.GetObjectIds()
 For Each blkId As ObjectId In idArray
                Dim obj As DBObject = tr.GetObject(blkId, OpenMode.ForRead)
                Dim blkRef As BlockReference = DirectCast(tr.GetObject(blkId, OpenMode.ForRead), BlockReference)
                Dim btr As BlockTableRecord = DirectCast(tr.GetObject(blkRef.BlockTableRecord, OpenMode.ForRead),      BlockTableRecord)
                If btr.IsFromExternalReference Then
                        MsgBox("yes")
                End If
Next
Instead of the message box, I want to get to the next step of picking up the attributes tho at that point btr is of External Reference type and doesn't contain any original block attributes (the Xref contains multiple blocks with multiple attributes so I need to drill down to this level).
Is there a way to turn btr to a certain type of object which is a collection of the blocks that the xref contains that I can cycle through?
so the code would be something like this (if possible?):
                             dim XrefBlockCollection as (some object array)
                             dim i as in int = 0
                             For Each id As ObjectId In XrefBlockCollection
                                  Dim ad As AttributeDefinition = TryCast(tr.GetObject(id, OpenMode.ForRead), AttributeDefinition)
                                        If ad IsNot Nothing Then
                                            print( ad.tag & ad.textstring )
                                         End If
                             next
                             end while
                    End If
Much appreciated for all your time
HD
Message 4 of 8
Alfred.NESWADBA
in reply to: hakand
check this:
   <Runtime.CommandMethod("ADESK_scanXRefs")> _
   Public Shared Sub ADESK_scanXRefs()
      Dim tMsgStr As String = ""
      Dim tAcadDoc As ApplicationServices.Document = Nothing
      Dim tDocLock As ApplicationServices.DocumentLock = Nothing
      Dim tTrAct As DatabaseServices.Transaction = Nothing
      Try
         tAcadDoc = ApplicationServices.Application.DocumentManager.MdiActiveDocument
         tDocLock = tAcadDoc.LockDocument
         tTrAct = tAcadDoc.Database.TransactionManager.StartTransaction
         tMsgStr &= "Start scan for References" & vbNewLine
         'first get XRefs from list of Block-Definitions
         Dim tBlTab As DatabaseServices.BlockTable = CType(tTrAct.GetObject(tAcadDoc.Database.BlockTableId, DatabaseServices.OpenMode.ForRead), DatabaseServices.BlockTable)
         For Each tObjID In tBlTab
            If (tObjID.IsValid) AndAlso (Not tObjID.IsErased) Then
               Dim tBlTabRec As DatabaseServices.BlockTableRecord = CType(tTrAct.GetObject(tObjID, DatabaseServices.OpenMode.ForRead), DatabaseServices.BlockTableRecord)
               If tBlTabRec.IsFromExternalReference OrElse tBlTabRec.IsFromOverlayReference Then
                  'get database of XRef-file
                  Dim tDB As DatabaseServices.Database = tBlTabRec.GetXrefDatabase(False)
                  tMsgStr &= vbNewLine & vbNewLine & "XRef=" & tDB.Filename & vbNewLine
                  'then scan the XRef
                  tMsgStr &= scanXRef(tDB)
               End If
            End If
         Next
         tMsgStr &= "Scan finished"
      Catch ex As Exception
      Finally
         If tTrAct IsNot Nothing Then tTrAct.Dispose() : tTrAct = Nothing
         If tDocLock IsNot Nothing Then tDocLock.Dispose() : tDocLock = Nothing
      End Try
      'and now you have the result in the variable tMsgStr
      Debug.Print(tMsgStr)
   End Sub
   Private Shared Function scanXRef(ByRef DB As DatabaseServices.Database) As String
      Dim tRetStr As String = ""    'here the attribtues get listet
      Try
         tTrAct = DB.TransactionManager.StartTransaction()
         'get modelspace
         Dim tBlTab As DatabaseServices.BlockTable = CType(tTrAct.GetObject(DB.BlockTableId, DatabaseServices.OpenMode.ForRead), DatabaseServices.BlockTable)
         Dim tBlTabRec As DatabaseServices.BlockTableRecord = CType(tTrAct.GetObject(tBlTab("*MODEL_SPACE"), DatabaseServices.OpenMode.ForRead), DatabaseServices.BlockTableRecord)
         'now scan for blockreferences
         For Each tObjID As DatabaseServices.ObjectId In tBlTabRec
            If (tObjID.IsValid) AndAlso (Not tObjID.IsErased) AndAlso (tObjID.ObjectClass.DxfName = "INSERT") Then
               Dim tBlRef As DatabaseServices.BlockReference = CType(tTrAct.GetObject(tObjID, DatabaseServices.OpenMode.ForRead), DatabaseServices.BlockReference)
               If (tBlRef.AttributeCollection IsNot Nothing) AndAlso (tBlRef.AttributeCollection.Count > 0) Then
                  'ok, we have attributes within the blockreference
                  For Each tAttID As DatabaseServices.ObjectId In tBlRef.AttributeCollection
                     If (tAttID.IsValid) AndAlso (Not tAttID.IsErased) Then
                        'get the AttributeReference and prepare it for export
                        Dim tAttRef As DatabaseServices.AttributeReference = CType(tTrAct.GetObject(tAttID, DatabaseServices.OpenMode.ForRead), DatabaseServices.AttributeReference)
                        tRetStr &= "BLockHandle=&h" & Hex(tBlRef.Handle.Value) & " / TAG=" & tAttRef.Tag & " / VALUE=" & tAttRef.TextString & vbNewLine
                     End If
                  Next
               End If
            End If
         Next
         tRetStr &= "Error in XRef: " & DB.Filename & ", msg: " & ex.Message & vbNewLine
      Finally
      End Try
      Return tRetStr
   End Function
for .NET-specific questions there is a special forum >>>here<<<
- alfred -
Alfred NESWADBA
Message 5 of 8
hakand
Wow that worked perfectly! ... Thanks so much for your help Alfred.
Sorry, didn't mean to post in the wrong section ... I was directed here from accidently posting another VB.net question in a general thread.
Is there anything I can add to:
Dim tDB As DatabaseServices.Database = tBlTabRec.GetXrefDatabase(True)
If the xref is no longer resolved? (the file no longer exists in which the xref is pointing to)
Because it errors out on the below line when it hits an Xref that is unresolved
With the error message:
Object reference not set to an instance of an object.
Also is there a way I can pick up the constant attributes of the blocks in the Xref?
I tried adding in the code in which I use to target my active drawing below but was unsuccessfull, above this line of code in which you provided me:
My constant attribute code:
                      For Each id As ObjectId In tBlTabRec
                            Dim ad As AttributeDefinition = TryCast(tTrAct.GetObject(id, OpenMode.ForRead), AttributeDefinition)
                                If ad.Constant = True Then
                                    If ad.Tag.ToUpper = "CATEGORY" Then
                                        grouparray.Add(ad.TextString)
                                    End If
                                End If
                            End If
                        Next
I wish to check all the block's constant attributes before cycle through the attributecollection.
Much appreciated for the time you've spent.
HD
Message 6 of 8
Alfred.NESWADBA
in reply to: hakand
>> Is there anything I can add to [...] If the xref is no longer resolved?
Yes, do a Try-Catch around it so it stays in the loop for scanning XRefs
IMHO the code you provided (searching for constant AttributeDefinitions in the BlockTableRecord) is ok, do that before the check for the AttributeReferences in the AttributeCollection of the BlockReference. So that's 2 steps and ok.
Maybe this answers the question better: No you don't find constant attribtues in the AttributeCollection.
- alfred -
Alfred NESWADBA
Message 7 of 8
wouter
Is it possible to rebuild the code with a hashtable for the collected attribute-output instead of the string?
When I try to collect the attributes in a hashtable in the scanXref function it only works for just 1 xref.
Is het possible to merge hashtables from the different xrefs?
tnx!
Wouter
Message 8 of 8
Alfred.NESWADBA
in reply to: wouter
Yes, it is possible, just create a hashtable and add the values from the attribtute into it.
I don't understand the question, sorry.
Then either create a key using the XRef-Name or make for each XRef a hashtable and create a new hashtable or collection and put the XRef-hashtable into it like a tree structure.
- alfred -
Alfred NESWADBA
”Boost
