RemoveHiddenLines property in R14 VBA?
Hello all.
Is this PS viewport property read only?
I can get the property, but cannot seem to be able to set the property?
This sample code reads the value with no problem, but I cannot seem to
change the value?
Sub Example_RemoveHiddenLines()
Dim pviewportObj As AcadPViewport
Dim center(0 To 2) As Double, width As Double, height As Double
center(0) = 3: center(1) = 3: center(2) = 0
width = 40: height = 40
ThisDrawing.ActiveSpace = acPaperSpace
Set pviewportObj = ThisDrawing.PaperSpace.AddPViewport(center, width,
height)
pviewportObj.Display True
Dim removeHidden As Boolean
removeHidden = pviewportObj.RemoveHiddenLines
MsgBox "The value of the RemoveHiddenLines property for the paperspace
viewport is " & pviewportObj.RemoveHiddenLines, ,
"RemoveHiddenLines Example"
End Sub
To set the value, I was trying:
pviewportObj.RemoveHiddenLines True
Set pviewportObj.RemoveHiddenLines=True
Neither worked. I am missing something simple, or is this a read only
value?
Warren Medernach
Joe
Warren Medernach wrote in message
news:88jqer$79d23@adesknews2.autodesk.com...
> Hello all.
> change the value?
> height)
> End Sub
> value?
> Warren Medernach
Thanks Joe.
But when I try that it comes back with:
Run-time error '-2147352567 (80020009)':
Cannot change active viewport
Here is what I have.
I am passing it the appropriate variables
Sub AddPViewport(dblCenterPt As Variant, dblWidth As Double, dblHeight As
Double)
Dim pviewportObj As Object
Set pviewportObj = ThisDrawing.PaperSpace.AddPViewport(dblCenterPt,
dblWidth, dblHeight)
pviewportObj.RemoveHiddenLines = True
End Sub
I just tried in 2000, and it works fine, but it will not work in R14.
I'm starting to think it's just plain broken in R14, I was hoping somebody
else could try it in R14.
Warren Medernach
"Joe Sutphin" wrote in message
news:88jvh4$79227@adesknews2.autodesk.com...
> Joe
> > Hello all.
> > change the value?
width,
> > height)
paperspace
> > End Sub
> > value?
> > Warren Medernach
Warren,
In R14, first toggle the display control of the PViewport object off.
Private Sub remHiddenLines(pvp As AcadPViewport, bFlag As Boolean)
ThisDrawing.MSpace = False
pvp.Display False
pvp.RemoveHiddenLines = bFlag
End Sub
Denis
Thanks Denis!
Warren Medernach
"Denis Gagne" wrote in message
news:88km5n$c2u13@adesknews2.autodesk.com...
> Warren,
> pvp.Display False
> End Sub
> Denis
