VBA
Discuss AutoCAD ActiveX and VBA (Visual Basic for Applications) questions here.
Reg. Plotting to PDF File without Opening Adobe Acrobat Reader
1 REPLY 1
3202 Views, 1 Reply
if (objAcadDoc != null)
// Plotagem Síncrona
objAcadDoc.SetVariable("BACKGROUNDPLOT", 0);
// Seleciona Layout
objAcadDoc.ActiveSpace = AcActiveSpace.acModelSpace;
// Configurações da Plotagem
objAcadDoc.ActiveLayout.PlotType = AcPlotType.acExtents;
//dm.ActiveLayout.StandardScale = AcPlotScale.ac1_1;
objAcadDoc.ActiveLayout.StandardScale = AcPlotScale.acScaleToFit;
objAcadDoc.ActiveLayout.PlotWithPlotStyles = true;
objAcadDoc.ActiveLayout.UseStandardScale = true;
objAcadDoc.ActiveLayout.CenterPlot = true;
objAcadDoc.ActiveLayout.StyleSheet = "monochrome.ctb";
if (IsRotationRequired)
objAcadDoc.ActiveLayout.PlotRotation = enmRotAngle;
// Aplica Estilo
//oAcadApp.Preferences.Output.DefaultPlotStyleTable = StyleTable;
objAcadDoc.Regen(AcRegenType.acActiveViewport);
// Gera Arquivo
objAcadDoc.Plot.QuietErrorMode = true;
objAcadDoc.Plot.NumberOfCopies = 1;
objAcadDoc.ActiveLayout.RefreshPlotDeviceInfo();
string destLoc = Path.Combine(clsCommon.com.c_OutputFolder, saveFileName);
objAcadDoc.Plot.PlotToFile(destLoc, "C:\\Program Files\\AutoCAD 2010\\UserDataCache\\Plotters\\DWG To PDF.pc3");
I have a code for plotting dwg to pdf file as mentioned above, but the problem is once plotting to pdf is completed for 1 file
it open Adobe Acrobat Reader with that file and I am working on 100 file simultaneously so is there
any way to plotting to pdf without openeing Adobe Acrobat Reader
1 REPLY 1
Alfred.NESWADBA
wether a PDF-viewer is opened after plotting or not depends on the setting in the "DWG to PDF.pc3", make your own pc3-file that has this option disabled and that's it.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
”Boost
