VBA
Discuss AutoCAD ActiveX and VBA (Visual Basic for Applications) questions here.
Reading blocks from model space
5 REPLIES 5
wilbert.barten
603 Views, 5 Replies
I use a routine to read all blocks from model space. It normally reads all blocks but now we have one issue.
A block is not read when it's placed below Y-coordinate -170.
- this is only on certain computers, on other computers it runs fine.
- this is only when the VBA program is started from paper space, if it's started from modelspace it reads all blocks.
Code I use to read all blocks:
  Set objAutoCad = ThisDrawing.Application
  Set objModelSpace = objAutoCad.ActiveDocument.ModelSpace()
  For Each objEntity In objModelSpace
    With objEntity
    If StrComp(.EntityName, "AcDbBlockReference", 1) = 0 Then
      If VBA.Left(VBA.UCase(objEntity.Name), 2) = "*U" Then
        MyBlockName = VBA.UCase(objEntity.EffectiveName)
      Else
        MyBlockName = VBA.UCase(objEntity.Name)
    End With
  Next
Since the problem is not on all computers I expect this problem is related to some setting in AutoCAD.
Any advice is appreciated.
Wilbert.
5 REPLIES 5
Hallex
in reply to: wilbert.barten
Just on the quick glance... Change:
"*U"
on
"`*U"
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
The extra ' makes no difference.
truss_85
Add to this,
objAutoCad.ActiveSpace = acModelSpace
What are the differences between two PC s operating system and acad versions.
wilbert.barten
in reply to: truss_85
objAutoCad.ActiveSpace = acModelSpace gives me Run-tiem error 438 Object doesn't support this propery or method.
I added:
ThisDrawing.ActiveLayout = ThisDrawing.Layouts("Model")
This solved the problem! THANK YOU!
Still strange to me it was running correct on 1 computer and not on another.
Both computers have Windows 7 enterprise, Service Pack 1.
Both computers have AutoCAD 2012 - 64 bits installed.
Kind regards,
Wilbert.
truss_85
I am glad to help. Since microsoft did not give any support to vba autodesk do it. If there is slightly difference between to machines libraries, it is effectable.
Best Regards...
”Boost
