I am trying to create MLeader with the current MultiLeaderStyle settings, which is annotative. The code which I use is:
Private Sub onMLeader(strText As String, varP1 As Variant)
Dim varP2 As Variant
Dim objMLeader As AcadMLeader
Dim LeaderPoints(0 To 5) As Double
On Error GoTo Done
varP2 = ThisDrawing.Utility.GetPoint(varP1, "Select Second Leader Point: ")
LeaderPoints(0) = varP1(0)
LeaderPoints(1) = varP1(1)
LeaderPoints(2) = varP1(2)
LeaderPoints(3) = varP2(0)
LeaderPoints(4) = varP2(1)
LeaderPoints(5) = varP2(2)
Dim i As Long
Set objMLeader = ThisDrawing.ModelSpace.AddMLeader(LeaderPoints, i)
objMLeader.TextString = strText
objMLeader.Update
Exit Sub 'Exit now
Done:
MsgBox Err.Description & vbCr & "MLeader Canceled!", vbCritical, "onMLeader()"
End Sub
My problem is that the resulting MLeaser is without landing(the properties of the Mleader shows length of the landing = 0) and the leader always starts from the left of the text, even if you start from the right, go horizontally to the left and the leader goes over the text. The strange thing is that the arrow head is correctly scaled, based on the currently selected annotative scale. If I grip the text and move it to the left and after that to the right the Mleader restores the landing, with its correct size from the MLeaderStyle and the text is located correctly relative to the landing, but I don’t like to do that with every mleader. I can force the mleader to put landing to the Mleader object but it seems counterintuitive, since its suppose to use the current MLeaderStyle Settings, like VLisp does. I also can force the landing to change depending of the location of the first and the second leader point thru the Dogleg member but I had the side effect that the coordinates of the second leader point were changed, while I wanted to keep them unchanged, so that the landing starts from them and force the text to move to the left or right based on first leader point. It looks to me like VBA builds first the mleader with the text to the right of the second mleader point and after that flips the landing, not the text, if needed, changing that way the second (landing) leader point. I like to have my leader from starting at my first point and ending in my second point.
Its annoying that I go that behavior from VLisp with this single expression:
(COMMAND ".mleader" LEADER_START LEADER_END DIAMETER_TEXT) and I hoped to have something as simple as this.
Any suggestions or ideas how to build a MLeader with all the setting of the current MLeaderStyle, or what is wrong with my code will be greatly appreciated?
Thank you
Solved by Hallex. Go to Solution.
Try this code
Option Explicit Sub test() Dim p1, p2 Dim vec(2) As Double Dim pts(5) As Double Dim i As Long Dim util As AcadUtility Dim space As AcadModelSpace Dim ml As AcadMLeader With ThisDrawing Set util = .Utility Set space = .ModelSpace End With Do While True With util p1 = .GetPoint(, vbCrLf & "Pick starting point:") p2 = .GetPoint(p1, vbCrLf & "Pick ending point:") pts(0) = p1(0): pts(1) = p1(1): pts(2) = p1(2) pts(3) = p2(0): pts(4) = p2(1): pts(5) = p2(2) End With Set ml = space.AddMLeader(pts, i) With ml .ContentType = acMTextContent If p2(0) > p1(0) Then .TextJustify = acAttachmentPointMiddleLeft vec(0) = 1: vec(1) = 0: vec(2) = 0 Else vec(0) = -1: vec(1) = 0: vec(2) = 0 .TextJustify = acAttachmentPointMiddleRight End If .DogLegged = True .DoglegLength = 0.09 .SetDoglegDirection i, vec .TextLeftAttachmentType = acAttachmentBottomOfTopLine .TextRightAttachmentType = acAttachmentBottomOfTopLine .TextString = "First Line\PSecond Line" End With Loop End Sub
~'J'~
Thank you for your response.
Your piece of code is very close to what I had in mind to do, but the annoying thing for which I was talking about, I mean the side effect, is when p1(0)>p2(0) then the leader is not build from p1 to p2 but it look like p2 is changed, in contrast of when p1(0) < p2(0) when the leader is exactly from p1 to p2. If you build two vertical lines and snap the mleader, once from left to right and second mleader from right to left you will see how when start from right and go to the left the mleader starts from the line and finishes at the second line (p1(0)<p2(0) case), but when you build you mleader from left to right (p1(0)>p2(0) case) your mleader line is pushed off the second line. Its annoying for me because when you build mleader thru autocad it does not behave that way.
Thank you for you code. I learned a lot programming from it.
Have a nice weekend
= How To Fix MLeader Second Point =
Now the text is located correctly relative to the landing, anyway on my machine,
not sure about if this code would be working correct with your variables and styles
(tested on A2009 only)
Option Explicit Sub test() Dim p1, p2 Dim vec(2) As Double Dim pts(5) As Double Dim leg As Double Dim i As Long Dim util As AcadUtility Dim space As AcadModelSpace Dim ml As AcadMLeader With ThisDrawing Set util = .Utility Set space = .ModelSpace End With leg = 0.0625 '<-- change to your suit On Error GoTo Err_Control Do While True With util p1 = .GetPoint(, vbCrLf & "Pick starting point (or hit Enter to Exit): ") p2 = .GetPoint(p1, vbCrLf & "Pick ending point: ") If p2(0) > p1(0) Then pts(0) = p1(0): pts(1) = p1(1): pts(2) = p1(2) pts(3) = p2(0): pts(4) = p2(1): pts(5) = p2(2) Else pts(0) = p1(0): pts(1) = p1(1): pts(2) = p1(2) pts(3) = p2(0): pts(4) = p2(1): pts(5) = p2(2) End If End With Set ml = space.AddMLeader(pts, i) With ml .ContentType = acMTextContent .DogLegged = True If p2(0) > p1(0) Then .TextJustify = acAttachmentPointMiddleLeft vec(0) = 1: vec(1) = 0: vec(2) = 0 Else vec(0) = -1: vec(1) = 0: vec(2) = 0 .TextJustify = acAttachmentPointMiddleRight End If .LandingGap = leg .SetDoglegDirection i, vec .DoglegLength = leg .TextLeftAttachmentType = acAttachmentBottomOfTopLine .TextRightAttachmentType = acAttachmentBottomOfTopLine .TextString = "First Line\PSecond Line" .SetLeaderLineVertices 0, pts ' <--fix the second point location .Update End With Loop Exit_Here: Exit Sub Err_Control: If Err.Description = "User input is keyword" Then Resume Exit_Here End If End Sub
__________________________________________________________________
"The whole problem with the world is that fools and fanatics are always
so certain of themselves, and wiser people so full of doubts."
Bertrand Russell
~'J'~
