Visual Basic Customization
doc_x
Message 1 of 6 (276 Views)
Problem with acCTRL
276 Views, 5 Replies
09-06-2012 06:38 AM
Hi !
I'm using that component. It's very good to my routines. But a problem has happened: When I put mouse on graphical environment and press key F2, so it 's lunching  total cad to front my application. Is it possible avoid that happen ?
I want to say, disable F2 from autoCad ? I'm using 2010 version.
Thanks !
doc_x
Message 2 of 6 (254 Views)
Re: Problem with acCTRL
09-09-2012 07:38 AM in reply to: doc_x
Nobody knows ?
I 'd like a simple direction.
Thanks !
Distinguished Mentor
andrewpuller3811
Message 3 of 6 (246 Views)
09-09-2012 07:06 PM in reply to: doc_x
Try looking up "shortcut keys" in the help.
In the CUI editor you can assign the "Cancel" which contains "^C^C" in the macro to the "F2" Key.
If this fixed your issue, click on "Accept as Solution"
Andrew Puller
Maitland, NSW, Australia
Windows 7 Enterprise 64bit
Intel core i7 2600 @ 3.40 GHz with 16GB Ram
Civil 3d 2013 64bit
doc_x
Message 4 of 6 (231 Views)
09-10-2012 05:04 PM in reply to: doc_x
Thanks! I'll try !
doc_x
Message 5 of 6 (222 Views)
09-11-2012 10:25 AM in reply to: doc_x
Hi Andrew, unhappylli I did not get yet.
andrewpuller3811
Message 6 of 6 (210 Views)
09-12-2012 08:08 PM in reply to: doc_x
What did you try? Write out the steps.
Maybe attach a screen shot.
Andrew Puller
Civil 3d 2013 64bit
You are not logged in.
Ask the Community
