• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Visual Basic Customization
    doc_x
    Problem with acCTRL
    184 Views, 5 Replies
    09-06-2012 06:38 AM
    Hi !
    I'm using that component. It's very good to my routines. But a problem has happened: When I put mouse on graphical environment and press key F2, so it 's lunching  total cad to front my application. Is it possible avoid that happen ?
    I want to say, disable F2 from autoCad ? I'm using 2010 version.
    Thanks !
    Please use plain text.
    doc_x
    Re: Problem with acCTRL
    09-09-2012 07:38 AM in reply to: doc_x
    Nobody knows ?
    I 'd like a simple direction.
    Thanks !
    Distinguished Mentor
    09-09-2012 07:06 PM in reply to: doc_x
    Try looking up "shortcut keys" in the help.
    In the CUI editor you can assign the "Cancel" which contains "^C^C" in the macro to the "F2" Key.
    If this fixed your issue, click on "Accept as Solution"
    Andrew Puller
    Maitland, NSW, Australia
    Windows 7 Enterprise 64bit
    Intel core i7 2600 @ 3.40 GHz with 16GB Ram
    Civil 3d 2013 64bit
    doc_x
    09-10-2012 05:04 PM in reply to: doc_x
    Thanks! I'll try !
    doc_x
    09-11-2012 10:25 AM in reply to: doc_x
    Hi Andrew, unhappylli I did not get yet.
    09-12-2012 08:08 PM in reply to: doc_x
    What did you try? Write out the steps.
    Maybe attach a screen shot.
    Andrew Puller
    Civil 3d 2013 64bit
