Visual Basic Customization
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Problem to populate a Listbox with informatio n from Entities
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
105 Views, 2 Replies
11-14-2012 03:03 AM
i have a little Problem here.
What i want to do is popluate a Listbox with with the area of previously selected Objects.
This is what i have at the moment:
i = 0 ListBox1.ColumnCount = 2 For Each ssetOBJ In sset objarea = ssetOBJ.Area i = i + 1 With ListBox1 .AddItem .List(.ListCount - i, 0) = "Fläche" .List(.ListCount - i, 1) = objarea End With Next
But the code only writes the area of the last Object in the first Row of the Listbox.
I think in the FOR EACH Expression the variable "i" pass always "1" for the Row Number.
Anyone knows why?
Thx for Help.
Re: Problem to populate a Listbox with informatio n from Entities
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
11-14-2012 12:17 PM in reply to:
whozi
You need to use 2 column listbox,
so you may want to use this code
just very basic though, change to suit
Private Sub CommandButton1_Click()
Me.Hide
Dim oSset As AcadSelectionSet
Dim oEnt As AcadEntity
Dim fcode(0 To 1) As Integer
Dim fData(0 To 1) As Variant
Dim dxfcode, dxfdata
Dim i As Integer, j As Integer, n As Integer, m As Integer, k As Integer
Dim setName As String
fcode(0) = 0
fData(0) = "LWPOLYLINE"
fcode(1) = 70
fData(1) = 1
dxfcode = fcode
dxfdata = fData
setName = "$PolyLines$"
'// make sure the selection set does not exist
For i = 0 To ThisDrawing.SelectionSets.Count - 1
If ThisDrawing.SelectionSets.Item(i).Name = setName Then
ThisDrawing.SelectionSets.Item(i).Delete
Exit For
End If
Next i
Set oSset = ThisDrawing.SelectionSets.Add(setName)
' oSset.Select acSelectionSetAll, , , dxfcode, dxfdata
oSset.SelectOnScreen dxfcode, dxfdata
' loop all polylines
ReDim dataArr(oSset.Count - 1, 0 To 1)
For n = 0 To oSset.Count - 1
Dim cEnt As AcadEntity
Set cEnt = oSset.Item(n)
Dim intPoints() As Variant
Dim oPline As AcadLWPolyline
Set oPline = cEnt
Dim ar As Double
ar = oPline.Area
Dim lyr As String
lyr = oPline.Layer
dataArr(n, 0) = ar
dataArr(n, 1) = lyr
Next n
oSset.Erase
ListBox1.Clear
ListBox1.ColumnWidths = "3cm;4cm"
ListBox1.ColumnHeads = True
ReDim layArr(0 To UBound(dataArr, 1), 0 To 1) As Variant
For i = 1 To UBound(dataArr, 1)
layArr(i - 1, 0) = dataArr(i - 1, 0)
layArr(i - 1, 1) = dataArr(i - 1, 1)
Next i
ListBox1.List() = layArr
Me.Show
End Sub
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
11-14-2012 10:21 PM in reply to:
Hallex
Very nice and clean code. Thx for Helping me out.
So i dont posted all my code.
I have found a Solution by myself.
I will post the code and the Solution that i found here as soon as possible.
