VBA
Discuss AutoCAD ActiveX and VBA (Visual Basic for Applications) questions here.
Possible? Select a specific PS Viewport...
9 REPLIES 9
Message 1 of 10
278 Views, 9 Replies
I have written code to create a named view, then set that named view. I do
not see a method to select a specific viewport in PS.
If I have 5 viewports, how do I choose between them using VBA code?
Thanks for the insight,
Dan
9 REPLIES 9
Message 2 of 10
I think you want to be saving a vport not a view. Now
restoring this vport in a paperspace layout and retrieve
with this idea.
Dim vport As AcadViewport
For Each vport In ThisDrawing.Viewports
Debug.Print vport.Name
Next vport
gl
Paul
"Dan" wrote in message
news:4883288@discussion.autodesk.com...
Dan
Message 3 of 10
for the view...
Dim view As AcadView
For Each view In ThisDrawing.Views
Debug.Print view.Name
Next view
"Paul Richardson" wrote in message
news:4883412@discussion.autodesk.com...
with this idea.
Next vport
gl
Paul
Dan
Message 4 of 10
Thank you for the input.
If I run the following code, "*Active" is returned. I need some way to make
sure a specific Viewport is active, and then set a named view.
Or even simpler, how would one cycle through each viewport?
Any help is greatly appreciated.
Dan
If I have 5 viewports in paperspace, how would I make changes to the bottom
right viewport for example.
with this idea.
Next vport
gl
Paul
Dan
Message 5 of 10
Is what I posted not what you want?
Next vport
news:4884916@discussion.autodesk.com...
Dan
with this idea.
Next vport
gl
Paul
Dan
Message 6 of 10
Thanks for the input.
Not sure if I am being clear or not.
If I have 5 viewports in paperspace, the code below just provide the name
"*Active".
This does not help me select the 5th viewort in the bottom righ-hand corner.
I am not sure how to go about it.
Dan
news:4884930@discussion.autodesk.com...
Next vport
Dan
with this idea.
Next vport
gl
Paul
Dan
Message 7 of 10
Dan, If you want paperspace viewports
use.
Dim pvport As AcadPViewport
For Each pvport In ThisDrawing.PaperSpace
Debug.Print pvport.ObjectName
Next pvport
Don't see a name property thougt. Don't know
if you can transfer the name of a saved view when
restoring as a paperspace viewport.
Paul
news:4886298@discussion.autodesk.com...
"*Active".
Dan
Next vport
Dan
with this idea.
Next vport
gl
Paul
Dan
Message 8 of 10
still no go....
news:4886388@discussion.autodesk.com...
use.
Next pvport
Paul
"*Active".
Dan
Next vport
Dan
with this idea.
Next vport
gl
Paul
Dan
Message 9 of 10
Dan
you're getting closer to answering your own question
The whole problem is how to *You* determine which viewport you want?
First off, which tab is it on?
Next, which viewport on that tab?
Now you say you want the one in the bottom right-hand corner.
assuming you know the coordinates of that viewport you can select it via a
selection set window as an example of one way to locate that particular
viewport
another way would be to iterate the viewports on that tab and check the
coordinates of each one in turn looking for a match to some pre-determined
criteria
another way would be to attach xdata to your viewports to tag them in some
way meaningful to yourself or your program.
etc
hth
Mark
Message 10 of 10
Thanks for the leads Mark.
I have never attached xdata yet, so I will do some research.
Dan
As far as cycling through the viewports with tab,
"MP" wrote in message
news:4886416@discussion.autodesk.com...
Dan
viewport
criteria
etc
hth
Mark
”Boost
