VBA
Discuss AutoCAD ActiveX and VBA (Visual Basic for Applications) questions here.
PlotToDevice failing in ACAD 2005
7 REPLIES 7
Message 1 of 8
tacito
472 Views, 7 Replies
my app permits to the users select multiple DWG files, inserting them into a MSHFLEXGRID.
After this the user can select a DWT file and store in a matrix (PC) all its AcadPlotConfigurations.
The user can select distinct Page Layout for each DWG file selected.
Then running the code below, each file is opened in ACAD and then printed using the specific Page Layout.
This was running very good in ACAD 2002. After migrate to ACAD 2005 only the first file is printed. The others DWG files return FALSE to the PlotToDevice command.
Is it missing some command ?
Does ACAD 2005 need anything extra to run ?
Obs: the DWT Page Layouts were created for MODELs and the files to be printed are using only the model space too.
Please, take a look in the code below
TIA,
Tácito Fieker
CADGRAPH
' PLOT SAMPLE
Dim PC() As AcadPlotConfiguration
Private Sub Plot_Click()
Dim Layout As AcadLayout
Dim LayoutBase As AcadLayout
Dim indice As Integer
Dim retorno As Boolean
Dim row As Integer
Dim j As Integer
' READ THE DWG FILES IN THE FLEXGRID
For row = 1 To MSHFlexGrid1.Rows - 1
retorno = False
MSHFlexGrid1.col = 0
MSHFlexGrid1.row = row
' OPEN A FILE
ThisDrawing.Application.Documents.Open (MSHFlexGrid1.Text)
' Get the Plot Configuration selected for this file
MSHFlexGrid1.col = 1
indice = BuscaPos(MSHFlexGrid1.Text)
On Error Resume Next
' Apply for the drawing
ThisDrawing.ActiveLayout.CopyFrom PC(indice)
ThisDrawing.ActiveLayout.RefreshPlotDeviceInfo
ThisDrawing.Plot.NumberOfCopies = 1
ThisDrawing.Plot.QuietErrorMode = False
retorno = ThisDrawing.Plot.PlotToDevice
MSHFlexGrid1.col = 3
If retorno = True Then
MSHFlexGrid1.CellBackColor = VBA.ColorConstants.vbGreen
Else
MSHFlexGrid1.CellBackColor = VBA.ColorConstants.vbRed
End If
ThisDrawing.Application.ActiveDocument.Close False
Next row
Next j
End Sub
7 REPLIES 7
Message 2 of 8
in reply to: tacito
I have a simular problem with PlotToDevice - see my post of
14-04-2005.
Stll no solution, so productivity is down with 99% with this.....
wrote in message news:4892277@discussion.autodesk.com...
into a MSHFLEXGRID.
TIA,
Tácito Fieker
CADGRAPH
' PLOT SAMPLE
Dim row As Integer
Dim j As Integer
retorno = False
' OPEN A FILE
Else
End If
Next row
Next j
End Sub
Message 3 of 8
in reply to: tacito
Have you turned _off_ background plotting?
R. Robert Bell
MSHFLEXGRID.
command.
TIA,
Tácito Fieker
CADGRAPH
' PLOT SAMPLE
Dim row As Integer
Dim j As Integer
retorno = False
' OPEN A FILE
Else
End If
Next row
Next j
End Sub
Message 4 of 8
in reply to: tacito
That did the trick for me.
Both plot and publish has to be turned off.
Wunderfull those new things everytime.....:)
"R. Robert Bell" wrote in message
news:4892940@discussion.autodesk.com...
R. Robert Bell
into a
MSHFLEXGRID.
all its
printed
only the
PlotToDevice
command.
TIA,
Tácito Fieker
CADGRAPH
' PLOT SAMPLE
Dim row As Integer
Dim j As Integer
retorno = False
' OPEN A FILE
Else
End If
Next row
Next j
End Sub
Message 5 of 8
tacito
in reply to: tacito
Robert,
including the command: ThisDrawing.SetVariable "BACKGROUNDPLOT", 0
solved the problem.
Tacito Fieker
Message 6 of 8
in reply to: tacito
Glad I could help both of you.
R. Robert Bell
wrote in message news:4893700@discussion.autodesk.com...
Robert,
solved the problem.
Tacito Fieker
Message 7 of 8
rvelozo
in reply to: tacito
I had the same error having the return value as false. So I ran a error routine until the printer is free again. This is how I got around it. Hope it helps:
On Error GoTo ErrorHandler
Finished = ThisDrawing.Plot.PlotToDevice(DeviceName)
Exit Sub
ErrorHandler:
Select Case Err.Number ' Evaluate error number.
Case -2147467259 ' Printer busy
Case Else
End Select
Resume
End Sub
Message 8 of 8
icyzola
in reply to: tacito
This solution works with AC2012 also and made my day. Thanks to everybody.
”Boost
