Visual Basic Customization
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Phantom text objects in dwg file
- Highlight
- Email to a Friend
Hello
I am attempting to use VBA in Acad 2007 to renumber a series of text objects based on their relative positions. (The text is numerals only.) The programs works well at first, but if I erase some of the text objects, it crashes. I noticed that if I start with 20 text objects in the drawing, and then erase 1, AutoCad reports 19 objects selected while ssetObj.Count is still equal to 20. Apparently the erased objects are still being returned by ssetObj.SelectOnScreen. To make sure I ran the example from a new drawing with only the text objects. Any ideas?
Thank you
John
Re: Phantom text objects in dwg file
- Highlight
- Email to a Friend
When you delete an object it's not removed from the SelectionSet-collection, it's just marked as "deleted". If you have 20 plates and you crash one, you will also have 20 plates, ok, one of them is broken to peaces, but the counter gives "20".
So show us your code-snippet where you walk through your SelectionSet and we may give you inputs what may be your problem. Without seeing the code it's a lot of guessing (and not more not guessing).
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at
- Highlight
- Email to a Friend
Hello
Thanks for your reply. Just to be clear, the text objects are erased before the selection set is picked. I have noticed that if I save the drawing to disk, then close the drawing and reopen it, the problem goes away. I would like to be able to edit the text objects, save the drawing and then run the renumber routine. Here is all the code.
Global yin(2500), xin(2500) As Double
Global handlein(2500) As String * 6
Global used(2500) As Boolean
Global inin(2500) As Long
Global csi%, cin&
Global firstnumber$
Global frnu%
Global thisy, thisx As Double
Private Sub CommandButton2_Click()
Dim ssetObj As AcadSelectionSet
Dim oTxt As AcadText
Dim FilterType(0) As Integer
Dim FilterData(0) As Variant
For i& = 0 To 2500
used(i) = False
Next i&
'On Error Resume Next
'ssetObj.Clear
'On Error GoTo 0
Set ssetObj = ThisDrawing.SelectionSets.Add("ss1")
If Err.Number <> 0 Then
Set ssetObj = ThisDrawing.SelectionSets.Item("ss1")
End If
On Error GoTo 0
UserForm1.Hide
' Return a point using a prompt
returnPnt = ThisDrawing.Utility.GetPoint(, "Pick First Text Object (Must Snap to Insertion Point)")
'select text data
FilterType(0) = 0 'Indicates filter refers to an object type
FilterData(0) = "Text" 'Indicates the object type is "Line"
'Code from www.visiblevisual.com
ssetObj.SelectOnScreen FilterType, FilterData
If ssetObj.Count = 0 Then
ssetObj.Delete
MsgBox ("Nothing Selected")
Exit Sub
End If
'vectorize text insertion points
cin& = 0
starty# = returnPnt(0): startx# = returnPnt(1)
On Error GoTo skipit
For i& = 0 To ssetObj.Count - 1
Set returnObj = ssetObj.Item(i&)
If returnObj.ObjectName = "AcDbText" Then
Set oTxt = returnObj
v = oTxt.InsertionPoint
yin(cin) = v(0): xin(cin) = v(1)
handlein(cin) = oTxt.Handle
cin& = cin& + 1
skipit:
End If
Next i&
On Error GoTo 0
cin& = cin& - 1
cinin& = 0
'find start point in text insertion vector
For i& = 0 To cin&
If ((yin(i) = starty) And (xin(i) = startx)) Then
'found start point
used(i) = True
starti& = i
inin(cinin&) = i
cinin& = cinin& + 1
thisy = starty#: thisx# = startx#
Exit For
End If
Next i&
'find next closest point
countdown& = 1
Do
inin(cinin) = findnext(thisy, thisx)
cinin = cinin + 1
countdown& = countdown& + 1
Loop Until countdown > cin
'renumber text
firstnumber$ = TextBoxFirstNumber.Text
frnu = Val(firstnumber$)
For i = 0 To cin
' Find an object from a given handle
Set oTxt = ThisDrawing.HandleToObject(Trim(handlein(inin(i))) )
oTxt.TextString = firstnumber$
frnu = frnu + 1
firstnumber$ = Str(frnu)
Next i
TextBoxFirstNumber.Text = firstnumber$
UserForm1.Show
End Sub
Function findnext(thisy, thisx) As Long
dmin# = 10000000
For j& = 0 To cin&
If Not used(j) Then
di# = Sqr((yin(j) - thisy) * (yin(j) - thisy) + (xin(j) - thisx) * (xin(j) - thisx))
If di < dmin Then
dmin = di
findnext = j
End If
End If
Next j&
used(findnext) = True
thisy = yin(findnext): thisx = xin(findnext)
End Function
Thank you again
John
- Highlight
- Email to a Friend
imho you forgot the .Clear when using the selectionset a second time, so you have the previously selected objects in the selectionset.
Try to modify:
ssetObj.Clear
End IfI have not tried your code, just read up to this point, let's see if it works now, if not let us know!.
- alfred -
Alfred NESWADBA
- Highlight
- Email to a Friend
Hello
I forgot to write in my original post that the error occurs trying to execute this statement
The error message is
Method 'Item' of object "IAcadSelectionSet' failed
Thank you
John
Re: Phantom text objects in dwg file Problem Solved
- Highlight
- Email to a Friend
Hello
That was the problem. Works perfectly now.
Many thanks
John
