VBA
Discuss AutoCAD ActiveX and VBA (Visual Basic for Applications) questions here.
Opening Drawings Using VB.Net
4 REPLIES 4
dhorger
1530 Views, 4 Replies
Hi folks,
I'm trying to open a list of drawings to perform operations on each one, but I've run into a snag. Here's the relevant code:
Dim dm As DocumentCollection = Application.DocumentManager
Dim doc As Autodesk.AutoCAD.ApplicationServices.Document
For x = 0 To lstFiles.Items.Count - 1
' open the drawing
doc = dm.Open(lstFiles.Items(x), ro)
' set the drawing current
dm.MdiActiveDocument = doc
' do stuff...
' close the drawing
doc.CloseAndDiscard()
Next
Here's the snag: when I try to make the most recently opened item the current drawing (using the line in bold), processing of the code stops until I manually set the focus back to the document that was open when I started the function. Once I do that, processing again starts at the next line of code. No errors pop up. What's the proper way to do this so that I can have the drawing that was just opened the current drawing?
Dave Horger
4 REPLIES 4
in reply to: dhorger
Hi Dave,
You've posted this to the VBA newsgroup.
You are far more likely to find expertise to resolve your problem in the
.NET newsgroup.
Laurie Comerford
dhorger@ieice.com wrote:
> Hi folks,
> ' open the drawing
> *dm.MdiActiveDocument = doc*
> ' do stuff...
> ' close the drawing
> Next
> Thanks,
> Dave Horger
You're using the .NET API so the .NET newsgroup is a better place to post.
Repost there rather than reply to this.
If your code is called from a command method, then you need to add the
CommandFlags.Session flag to the CommandMethod attribute.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD
Supporting AutoCAD 2000 through 2010
http://www.acadxtabs.com
Email: string.Format("{0}@{1}.com", "tonyt", "caddzone");
wrote in message news:6239908@discussion.autodesk.com...
Hi folks,
' open the drawing
' do stuff...
' close the drawing
Next
Dave Horger
dhorger
Thanks! That did the trick.
And I'll remember to post in the .Net newsgroup, next time.
Dave
spesci
Dave,
I don't know where do you put this?
What did you have to put in?
Scott
”Boost
