Open dwg file from code
OceanaPolynom
OceanaPolynom
Hello
I want to open a dwg file from code in my program.  I have a string variable containing the full path and file name.  I want to open the dwg file in an instance of Autocad that is already running, I don't want to open Autocad.  The program is written in VB 6.0.  Is this possible?
Thank you
John
Alfred.NESWADBA
yes, is possible, use COM/ActiveX to get access to the running AutoCAD instance and start controlling it.
   Dim tAcadApp as AcadApplication   'or    as Object     if you use latebinding
   Set tAcadApp = getObject(,"AutoCAD.Application")
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
OceanaPolynom
Thanks for your reply.  I am finding out what this is meanwhile
John
