VBA doesn't reference DLLS it references type libraries.
Type libraries can exist in either a DLL/OCX or a .TLB file.
So, the problem is that the AxDb15.dll is not registered on
the problem system.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005
http://www.acadxtabs.com
"Spageddie" wrote in message
news:16839440.1095887896529.JavaMail.jive@jiveforum1.autodesk.com...
> After much reading on ObjectDBX, I followed "The Wonder Llama's" ObjectDBX Example
(http://www.cadvault.com/forums/showthread.php?t=2881) and created my app, which work fine on my machine, but when I
try and use the application from another machine it fatals autocad.
> I tracked the problem to AXDB15.TLB being referenced, is this correct ?
> Because if I reference axdb15.dll I don't get the fatal and all works well.....??
> The reason I ask is
> Quote:
> Just to be clear -
> you DON'T reference axdb15.dll
> you DO reference AXDB15.TLB
> taken from the link above.
> Can someone clarify this or give me hint as to why I have this issue ?
