Named Layer Filters
Named Layer Filters
Message 1 of 11
Named Layer Filters
Is there a way to access a drawing's Named Layer Filters via VBA?
Replies (10)
Message 2 of 11
Yes, it's posted in these NG's at least once a day.
"spanqy" wrote in message
news:f1a441d.-1@WebX.maYIadrTaRb...
via VBA?
Message 3 of 11
Everyday, huh? Not quite RK! If you're going to take the time to post, at least be constructive and give me a link to one of these posts - it would save the both of us time.
Message 4 of 11
Whilst RK's reply was a little sarcastic, this newsgroup does encourage people seeking information to do their own searches first rather than having the answers (ie links) spoon-fed to them.
Just my two cents.
Wayne Ivory
IT Analyst Programmer
Wespine Industries Pty Ltd
Message 5 of 11
    Dim oDict As
AcadDictionary
    Dim LayFlt As Object
Dim oXrec As AcadXRecord
    Dim xType As Variant, xValue As
Variant
    Set oDict =
ThisDrawing.Layers.GetExtensionDictionary
    Set LayFlt =
oDict.item("ACAD_LAYERFILTERS")
    Set oXrec =
LayFlt("nplt")
    oXrec.GetXRecordData xType,
xValue
    MsgBox "Layer Filter name: " &
xValue(0)
Kevin
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
Is
VBA?
Message 6 of 11
Thanks a bunch Kevin!
Message 7 of 11
I agree, but how can he (or anyone) assume that I didn't already do just that?
Message 8 of 11
Spangy,
The only reason anyone could assume it, is because IF you had done a search
(like I just tested) you would've found about 50 messages in this newsgroup
dealing with this subject and in at LEAST one of them was the answer to your
question...... 😉
Jeff
news:f1a441d.5@WebX.maYIadrTaRb...
that?
Message 9 of 11
I could never get that to work here with Netscape (NNTP Error - command not recognized). I'm always forced to "manually" scan the posts to find what I'm after - NOT easy, but I do my best. Perhaps you can give me a suggestion in this regard?
That's what this board is all about right?
Message 10 of 11
Try Google.com. They mirror this ng. Use the
following syntax to narrow the search to this ng.
This will find post with the 3 words anywhere in
the post:
named layer
filter group:autodesk.autocad.customization.vba
This will find post with the 3 words together
in the post:
"named layer
filter" group:autodesk.autocad.customization.vba
Ed
I
this regard?
Message 11 of 11
Thanks a lot Ed!
