Hi NeedHelpinVBA,
Try this:
{code}
P1-2[& Prototype]^C^C^C(vl-vbarun "C:\\Program Files\\New Menu\\code.dvb!AAStartThePrototype")
{code}
You can test this from the command line with:
{code}
{code}
If it doesn't wok, you may need the use (vl-load-com) first
Laurie Comerford
NeedHelpinVBA wrote:
> Hello All,
> I managed to create a personnalized menu that I can add in the menu bar but I would like to customize each item of this drop down menu. I mean that when you click on the first label for instance you have access to a function that I coded in VBA.
> This menu works when I write "P1-2[&Prototype]^C^CCopy" for example. But I would like to access my function instead of Copy.
> Here is what I tried:
> ***MENUGROUP=TEST1
> ***POP1
> P1-1[& Test]
> P1-2[& Prototype]^C^C(vl-vbaload "\\C:\Program Files\New Menu\code.dvb")(vl-vbarun "AAStartThePrototype")
> This code does not work.. Can you help me please?
> Thanks,
> Regards,
