VBA
Discuss AutoCAD ActiveX and VBA (Visual Basic for Applications) questions here.
Loading VBA files - display clean Command Line
0 REPLIES 0
Message 1 of 1
junoj
363 Views, 0 Replies
when I load the VBA via:
(defun c:tst ()    ( vl-vbarun  "Path/DVB.dvb!Testing.test" ))
The code runs without any problems but the command line display several lines with location of the code. Is there a way to make the command behave like other commands with a clean command line sowing only the command input?
Thank you,
-J
0 REPLIES 0
”Boost
