Jonathan -
The code is for copying a single plotstyle reference from one drawing to
another, using DBX to read the source drawing without actually opening it..
For whatever reason, you can't use VBA to assign a plot style to a layer
unless the plot style is already listed in the drawing in a dictionary
called "acad_plotstylename."
For example, say you need to assign the plot style "Black" to the layer
"Fred", but the style "Black" is not already in use in the drawing. If you
try to assign the plotstyle using the following code, you'll get an error:
ActiveDocument.Layers("Fred").Plotstylename = "Black"
I know no way of accessing the .stb file directly, so I create a master .dwg
file containing layers that use all the plot styles in the .stb file. Thus
all the plotstyles in the .stb file are listed in "acad_plotstylename"
dictionary of the master file. I then use the dbx_copy_pstyle to copy the
plot style references from the master file into any other drawing in which I
need them.
Here's how I do it:
On error resume next
If err.number <> 0 then
Err.clear
dbx_copy_pstyle masterfilename, "Black"
End if
What happens is that if the plotstylename assignment fails, dbx_copy_pstyle
copies the plot style reference into the drawing, then it tries the
assignment again.
Keep in mind that nothing except the plotstyle name is stored in the drawing
file. All the actual plot style information is taken from the .stb file. You
just have to have the plotstyle listed in the drawing to be able to use it.
I hope I'm helping you rather than confusing you more. This is a pretty
roundabout way of doing something that should be simple, but AutoDesk forgot
to provide the simple way.
Tony
"Jonathan Stewart" wrote in message
news:A22EFFEB2F584BC1B35E7A1FF35CDC94@in.WebX.maYIadrTaRb...
> Tony,
> Ok, I've regestered the dll, and added the references.
> I must be missing something else. Do I set the filename to a drawing file
> or .stb file?
> And is this code for adding just one individual pstyle?
> I just really feel clueless.
> Jonathan
> "Tony Burba" wrote in message
> news:D53C656397095D738BAFDCCB042DAB42@in.WebX.maYIadrTaRb...
> > Johnathan -
> > Sorry. Before you can use the dbx functions, you need to register the
dll.
> > Go to the Windows command prompt (not the AutoCad command line, but the
> > Windows Dos-style command interface) and run the following:
> > regsvr32 /s "c:\program files\Autocadpath\axdb15.dll"
> > (in place of AutoCadpath put the path to the acad application directory)
> > Then add references to ObjectDbx 1.0 Type Library to your project.
> > Dictionaries are where AutoCad stores non-graphic information in your
> > drawing. See developer documentation for more info.
> > Tony
> > news:62CAE62C813B0E285717901BD112FF51@in.WebX.maYIadrTaRb...
> > > Tony,
> > > Thanks for the response.
> > > I do have the linetypes working, but the plot styles are blowing me
> away.
> > Is
> > > there additional Type Libraries that I should be referencing for this
> > code?
> > > Excuse my ignorance, but I'm only a "novice/intermediate" programmer.
> > I've
> > > never used the AcadDictionary.
> > > Thanks,
> > > Jonathan
> > > news:D042D083D025496509BD078FE46F1523@in.WebX.maYIadrTaRb...
> > > > Jonathan -
> > > > You don't really "load" plot styles into the drawing. There's simply
a
> > > > dictionary that lists the plot style names available in the drawing,
> but
> > > the
> > > > plot style information still comes directly from the .stb file. What
I
> > do
> > > is
> > > > keep a master file with all the plot styles I use, then use the
> > following
> > > > code to get the plot style references into my other drawings:
> > > > Public Function dbx_copy_pstyle(filename As String, pstyle As
String)
> > > > On Error GoTo Handler
> > > > Dim dxbdoc As New AXDB15Lib.AxDbDocument
> > > > Dim xtyps As Variant, xvals As Variant
> > > > Dim sourcedic As AcadDictionary
> > > > Dim destdic As AcadDictionary
> > > > Dim sourcerec As AcadObject
> > > > Set dxbdoc =
> > > > AcadApplication.GetInterfaceObject("ObjectDBX.AxDbDocument")
> > > > dxbdoc.Open filename
> > > > Set sourcedic = dxbdoc.Dictionaries("acad_plotstylename")
> > > > Dim objarr(0) As AcadObject
> > > > Set sourcerec = sourcedic(pstyle)
> > > > Set objarr(0) = sourcerec
> > > > Set destdic = ActiveDocument.Dictionaries("acad_plotstylename")
> > > > dxbdoc.CopyObjects objarr, destdic
> > > > Set dxbdoc = Nothing
> > > > Set sourcedic = Nothing
> > > > Set destdic = Nothing
> > > > Exit Function
> > > > Handler:
> > > > If Err.number <> 0 Then
> > > > ActiveDocument.Utility.Prompt vbCrLf & Err.number & " " &
> > > > Err.Description
> > > > err.clear
> > > > End If
> > > > End Function
> > > > Linetypes are a lot easier. Use something like this:
> > > > Dim linetypename as string
> > > > linetypename = "hidden2"
> > > > Dim ltyp As AcadLineType
> > > > With ActiveDocument.Linetypes
> > > > Set ltyp = .Item(linetypename)
> > > > Err.Clear
> > > > .Add (linetypename)
> > > > End If
> > > > End With
> > > > Set ltyp = Nothing
> > > > Hope this helps
> > > > news:583E478FA870744D1C19EA39DD370507@in.WebX.maYIadrTaRb...
> > > > > Does anyone know how I can load a .stb file in a drawing along
with
> > all
> > > > the
> > > > > Named Plot Styles that are contained in the .stb?
> > > > > The same for Linetypes in a .lin?
> > > > > I am wanting to assign Plot Styles and linetypes to layers in a
> > drawing,
> > > > but
> > > > > cannot automate this through VBA without the individual Named Plot
> > > Styles
> > > > or
> > > > > Linetypes loaded in the drawing.
> > > > > Any help would be greatly appreciated.
> > > > > Jonathan Stewart
