may I introduce you to the VBA (for AutoCAD) -HELP 😉
you find there all objects and all methods/properties and for (nearly) all methods you have examples to take.
Look how I would solve your questions using the help within the video.
- alfred -
Found in my oldies
Option Explicit '---------------------------------------------------------- ' Function to determine if a layer exists '---------------------------------------------------------- ' **** Kusleika's method Public Function LayerExists(lyrName As String) As Boolean Dim oLayer As AcadLayer On Error Resume Next Set oLayer = ThisDrawing.Layers(lyrName) LayerExists = (Err.Number = 0) End Function '---------------------------------------------------------- ' Function to determine if a linetype exists '---------------------------------------------------------- ' **** Kusleika's method Public Function LineTypeExists(ltpName As String) As Boolean Dim oLineType As AcadLineType On Error Resume Next Set oLineType = ThisDrawing.Linetypes(ltpName) LineTypeExists = (Err.Number = 0) End Function '---------------------------------------------------------- ' Function to set an existing layer or create a new drawing layer '---------------------------------------------------------- Function AddLayer(layerName As String, ltpName As String, intColor As Long, intLweight As Integer, strDesc As String, Optional blnPlot = True) As AcadLayer Dim oLayer As AcadLayer With ThisDrawing Dim strVer As String strVer = "AutoCAD.AcCmColor." + Left(CStr(.GetVariable("ACADVER")), 2) Dim acmColor As AcadAcCmColor Set acmColor = AcadApplication.GetInterfaceObject(strVer) acmColor.ColorIndex = intColor ' Add the layer to the layers collection Set oLayer = .Layers.Add(layerName) On Error Resume Next If Not LineTypeExists(ltpName) Then If .GetVariable("MEASUREINIT") = 0 Then .Linetypes.Load ltpName, "acad.lin" Else .Linetypes.Load ltpName, "acadiso.lin" End If End If oLayer.Linetype = ltpName oLayer.Lineweight = intLweight oLayer.TrueColor = acmColor ' Put plottable if does not defined in the calling function If Not blnPlot Then oLayer.Plottable = Not oLayer.Plottable oLayer.Plottable = blnPlot End If ' Put description oLayer.Description = strDesc ' Make the new layer the active layer for the drawing .ActiveLayer = oLayer End With Set acmColor = Nothing Set AddLayer = oLayer End Function Sub bb() Call AddLayer("ALAYER", "DASHDOT2", 162, 60, "My description") End Sub
