VBA
Discuss AutoCAD ActiveX and VBA (Visual Basic for Applications) questions here.
Layer color promt?
8 REPLIES 8
Message 1 of 9
293 Views, 8 Replies
Layer color promt?
How can I call the layer color promt and capture the users selection trough
vb/vba. If I use windows color object then the knowncolors do not match
acad's.
Andy
8 REPLIES 8
Message 2 of 9
Andrew Elmore
courtesy of Randall Rath:
calling sub:
Dim lColor As Long
lColor = ChooseColor(lColor, True, lColor)
'Color choice using autocad color selection dialog box
Public Function ChooseColor(ByVal lngInitClr As Long, _
ByVal blnMetaColor As Boolean, _
ByVal lngCurClr As Long) As Long
ChooseColor = -1
On Error Resume Next
If acedSetColorDialog(lngInitClr, blnMetaColor, lngCurClr) Then
ChooseColor = lngInitClr
End If
On Error GoTo 0
End Function
Cheers
Juerg Menzi
MENZI ENGINEERING GmbH, Switzerland
http://www.menziengineering.ch
Message 3 of 9
Thanks for the reply buy what do I dim "acedSetColorDialog" to. It's looking
for a function but I still can not get the color promt.
Andy
"Jürg Menzi" wrote in message
news:3F048616.F9D4FF50@bluewin.ch...
> Andrew Elmore
> calling sub:
> Dim lColor As Long
> ChooseColor = -1
> End If
> On Error GoTo 0
> End Function
> Cheers
> Juerg Menzi
Message 4 of 9
Maybe check randall's site - maybe the function is there, or there's some
reference needing set. I couldn't find it in the help either.
"Andrew Elmore" wrote in message
news:11974486DB472FF46FFBF4BA841F0F06@in.WebX.maYIadrTaRb...
looking
Message 5 of 9
Andrew
Ok, ok I shut too fast... you need to declare the AutoCAD API:
Public Declare Function acedSetColorDialog Lib "acad.exe" ( _
ByRef intColor As Long, _
ByRef fAllowMetaColors As Boolean, _
ByRef intNewColor As Long) As Boolean
Cheers
Juerg Menzi
Message 6 of 9
Okay i must be an idot because i still can not get this work.
Andy
news:3F05369B.1FBD816F@bluewin.ch...
> Andrew
> Cheers
> Juerg Menzi
Message 7 of 9
Andy
This is my implementation of Randall's color dialog sample:
Private Declare Function acedSetColorDialog Lib "acad.exe" (Color As Long, _
ByVal bAllowMetaColor As Boolean, ByVal nCurLayerColor As Long) As Boolean
Public Function MeGetAcadColor(DefCol As Long, MtaCol As Boolean, _
LayCol As Long) As Long
MeGetAcadColor = -1
If acedSetColorDialog(DefCol, MtaCol, LayCol) Then
MeGetAcadColor = DefCol
End If
End Function
Works with A2k, A2ki and A2k2...
Cheers
Juerg Menzi
Message 8 of 9
I figured out my problem. I needed to change the declare to Private not
public.
Andy
news:3F091585.77DC76E7@bluewin.ch...
> Andy
_
> MeGetAcadColor = -1
> End If
> End Function
> Cheers
> Juerg Menzi
Message 9 of 9
Cheers
Juerg Menzi
”Boost
