VBA
Discuss AutoCAD ActiveX and VBA (Visual Basic for Applications) questions here.
Is this possible with GetRemoteFile method
1 REPLY 1
Eddie68
406 Views, 1 Reply
I'm trying to download a .dvb file from my Web site and load it locally into AutoCAD. I can download with the Getremotefile method with out any problems. The problem is with the downloaded file, it is unusable. When I try to load the file manually I get a message indicating 'unable to load file'. In comparing the downloaded file size with the file on my Web server, the downloaded file is considerably smaller.
So, hopefully someone can tell me if I'm doing something wrong?
Code:
Dim strURL As String
Dim strLocalName As String
strUrl = "http://DomainName/myFile.dvb"
thisDrawing.utility.getremotefile strUrl, strLocalName, true
Thanks in advance!
1 REPLY 1
andy62
in reply to: Eddie68
Hi Eddie
I hope this code help you
andrea
strLocalFilePath = "c:\storedfile"
strLocalFile = ""
strLocalUrl = strLocalFilePath & "\ACAD\" & "myFile.dvb"
strRemoteUrl = "http://DomainName/myFile.dvb"
Utility.GetRemoteFile(strRemoteUrl, strLocalFile, True)
On Error Resume Next
FileSystem.MkDir(strLocalFilePath & "/ACAD")
FileSystem.FileCopy(strLocalFile, strLocalUrl)
On Error GoTo 0
If Utility.IsRemoteFile(strLocalFile, strRemoteUrl) Then
boolDownload = True
Else
boolDownload = False
End If
”Boost
