VBA
Discuss AutoCAD ActiveX and VBA (Visual Basic for Applications) questions here.
Insert Block
14 REPLIES 14
Message 1 of 15
cynide123
6547 Views, 14 Replies
Insert Block
I am new to autocad VBA and I am facing this problem:
When user clicks "Done" button on userform, program loads a predefined drawing and then inserts block from SADD1000S.dwg. Above command works fine when I click "Done" for the first time, but when I click "Done" again, program throws runtime error.
Private Sub CommandButton4_Click()
Application.Documents.Open ("C:\Users\Admin\Desktop\BACK UP\VBA\Final\set")
Dim objBlockRef As AcadBlockReference
Dim varInsertionPoint(0 To 2) As Double
Dim dblX As Double
Dim dblY As Double
Dim dblZ As Double
Dim dblRotation As Double
dblX = 1
dblY = 1
dblZ = 1
dblRotation = 0
varInsertionPoint(0) = 256
varInsertionPoint(1) = 256
varInsertionPoint(2) = 0
Set objBlockRef = ThisDrawing.ModelSpace.InsertBlock(varInsertionPoint, "C:\Users\Admin\Desktop\BACK UP\VBA\Final\SADD1000S.dwg", dblX, dblY, dblZ, dblRotation)
End Sub
Can anyone suggest what might the problem be?
14 REPLIES 14
Message 2 of 15
Alfred.NESWADBA
in reply to: cynide123
what have you tried from my suggestions >>>here<<<?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 3 of 15
RICVBA
I guess it's because the "Application.Documents.Open" method is always called for the same file, so that after its first calling subsequent files are opened in "readonly" mode which shouldn't allow you any document modifications, like a block insertion is.
if you need to insert blocks in the same document you'll have to check whether the file of interest is already open and, if not, open it. otherwise set it as the ActiveDocument
Message 4 of 15
cynide123
in reply to: Alfred.NESWADBA
"No, I guess it's not the open/close of the inserted drawing as AutoCAD closes the file-access after the insertion by itself, there is nothing open afterwards."
this is true... in above code when I remove "Application.Documents.Open ("C:\Users\Admin\Desktop\BACK UP\VBA\Final\set")" it works fine
execution stops at "Set objBlockRef = ThisDrawing.ModelSpace.InsertBlock(varInsertionPoint, "C:\Users\Admin\Desktop\BACK UP\VBA\Final\SADD1000S.dwg", dblX, dblY, dblZ, dblRotation)" giving runtime error.
After your last suggestion, I extracted the part of code (as pasted above) which is causing problem. First I thought it was due to some problem in one of the many "if" or "for" statements i was using in original program, but after ur suggestion, i made a small test programe to test the actual problem....
Message 5 of 15
cynide123
in reply to: RICVBA
@RICVBA
i have added this at the end of program,
ThisDrawing.Application.ActiveDocument.Close (False)
I still get the same error when I click "done"
Message 6 of 15
RICVBA
my advice was to check and, if necessary, open the desired file. this because Autocad VBA online Help says "In-process clients (VBA macros) may notice that objects are not destroyed until the subroutine is exited. However, references to destroyed objects are not recommended at all, even in the in-process code"
so try this
Dim DwgFullName As String
DwgFullName = "C:\Users\Admin\Desktop\BACK UP\VBA\Final\set.dwg"
If ActiveDocument.FullName <> DwgFullName Then Application.Documents.Open (DwgFullName)
Dim dblX As Double
Dim dblY As Double
Dim dblZ As Double
dblX = 1
dblY = 1
dblZ = 1
dblRotation = 0
End Sub
Message 7 of 15
cynide123
in reply to: RICVBA
Thanks for the the prompt reply, I tried the above code.... I am still getting runtime error (file error) on this line:
Message 8 of 15
RICVBA
since i'm getting no errors with that code snippet I suggested you'd better post your entire code (calling sub, and userform code) and the files involved (both "set" and "SADD1000S") so that I could have a thorough look at them
and specify your autocad version
Message 9 of 15
Alfred.NESWADBA
So the line with "...Insert..." basically works without issues, that's what had to be proofed first.
Now the next step is to verify the state of "ThisDrawing." used in that line. Try to change the following lines to:
Dim tAcadDoc as AcadDocument
Set tAcadDoc = Application.Documents.Open ("C:\Users\Admin\Desktop\BACK UP\VBA\Final\set")
'...your code lines
Set objBlockRef = ThisDrawing.ModelSpace.InsertBlock(varInsertionPoint, "C:\Users\Admin\Desktop\BACK UP\VBA\Final\SADD1000S.dwg", dblX,dblY, dblZ, dblRotation)
Set objBlockRef = tAcadDoc.ModelSpace.InsertBlock(varInsertionPoint, "C:\Users\Admin\Desktop\BACK UP\VBA\Final\SADD1000S.dwg", dblX, dblY, dblZ, dblRotation)
Let's know if it works in that way!
HTH, - alfred -
Alfred NESWADBA
Message 10 of 15
RICVBA
@Alfred
I'm quite sure it's a "readonly" file issue
so it shouldn't matter if referencing it via ThisDrawing or a specific document object. we have only to care not to re-open it if already open since this would result in a readonly file with the same name.
what's strange is that I had no problems with the last sub I posted while cynide123 still have.
so it will be of some interest have a look at its code and files
Message 11 of 15
cynide123
in reply to: RICVBA
@Alfred tried your solution, still NO luck.
@RICVBA i am using autocad 2008. I shall try to replace set and sadd1000s files in my system ad give it a try, else i'll extract the code in a new vba project and attach here
Message 12 of 15
cynide123
in reply to: RICVBA
attacted the project file (stripped from original program, but the problem still persists)
"set" and "sadd1000s" files
Clicking "Done" in userform1 once does the job, second time runtime error occurs.
Message 13 of 15
Alfred.NESWADBA
I ran your code, three clicks, no error/no exception. Additionaly info: I'm running 2014
As RICVBA already mentioned ... there is no close built in, so the drawing "SET.DWG" is then 3 times opened (two of them as "read-only".
One additional try (don't know where I have read that, but there was a difference): put the string with the filename into a variable and not directly into the insert-statement.
   Dim tFileName as String
   tFileName = "C:\Users\Admin\Desktop\BACK UP\VBA\Final\SADD1000S.dwg"
   Set objBlockRef = tAcadDoc.ModelSpace.InsertBlock(varInsertionPoint, tFilename, dblX, dblY, dblZ, dblRotation)
Maybe it is a help for your system.
Also look to the servicepacks for your AutoCAD >>>click<<<
- alfred -
Alfred NESWADBA
Message 14 of 15
cynide123
works well when I installed service pack 1 for autocad 2008... Thanks a lot Alfred and RICVBA.
Message 15 of 15
  //Hello my name is Dario
        //'m from Brazil
        //can someone help me?
        //insert a block, and in the sequel want the data of this block,
        //and then delete this block
        //as the example in the main code, just below ..
        //I have these questions that are commented no Main method >>???????
        //Main method
        [CommandMethod("Blockk")]
        public void blockk()
          Document doc = Host.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
          string[] data = new string[3];
          data[0= "data 1";
          data[1= "data 2";
          data[2= "data 3";
          BlockReference db = InsertBlockFromFile_(doc@"C:\wbc\orienta.dwg"new Point3d(505050), Math.PI * 0.25,
            "wbc_insert"data303017truenull"wbcd");
            //??????? return..>>> Example
            //??????? db.insertionPoint
            //??????? db.angle
            //??????? db.handle
            //??????? db.Xproprierts
            //??????? db.Atrib
            //??????? db.erase
        //Complementary methods
        public static BlockReference InsertBlockFromFile_(Document docstring DrawingFilePoint3d Pinsertdouble Angle,
        string Layerstring[] DadosExtendidos = nulldouble escalax = 1.0double escalay = 1.0double escalaz = 1.0short ColorLayer = 7,
        bool ModelSpace = truestring[] Atributos = nullstring RegAplicacao = "wbc")
            if (!System.IO.File.Exists(DrawingFile))
                MessageBox.Show("Drawing not found\n" + DrawingFile);
                return null;
            string sourceFileName = DrawingFile;
            string Blockname = System.IO.Path.GetFileNameWithoutExtension(sourceFileName);
            try
                using (Transaction tr = doc.TransactionManager.StartTransaction())
                    Database db = new Database(falsefalse);
                    db.ReadDwgFile(DrawingFileSystem.IO.FileShare.Readtruenull);
                    ObjectId BlkId = doc.Database.Insert(Blocknamedbtrue); // ISL: Small fix, use correct block name
                    tr.Commit();
            catch (IOException ioe)
                MessageBox.Show(ioe.Message);
                return null;
            return AddBlockTest_(docBlocknamePinsertAngleLayerDadosExtendidosescalaxescalayescalazColorLayerAtributosRegAplicacao);
        private static BlockReference AddBlockTest_(Document docstring blockNamePoint3d Pinsertdouble Angle,
        string Layerstring[] DadosExtendidos = nulldouble escalax = 1.0double escalay = 1.0double escalaz = 1.0,
        short ColorLayer = 7string[] Atributos = nullstring Regaplicacao = "wbc")
            Database db = doc.Database;
            using (Transaction myT = db.TransactionManager.StartTransaction())
                //Get the block definition "Check".
                BlockTable bt =
                    db.BlockTableId.GetObject(OpenMode.ForReadas BlockTable;
                BlockTableRecord blockDef =
                  bt[blockName].GetObject(OpenMode.ForReadas BlockTableRecord;
                BlockTableRecord ms = (BlockTableRecord)myT.GetObject(db.CurrentSpaceIdOpenMode.ForWrite);
                //Create new BlockReference, and link it to our block definition
                using (BlockReference blockRef =
                        new BlockReference(PinsertblockDef.ObjectId))
                    blockRef.Rotation = Angle;
                    blockRef.ScaleFactors = new Scale3d(escalaxescalayescalaz);
                    //Add the block reference to modelspace
                    ms.AppendEntity(blockRef);
                    myT.AddNewlyCreatedDBObject(blockReftrue);
                    SetXData_(blockRefRegaplicacao , DadosExtendidosdoc);
                    CreatLayer_(LayerdocColorLayer);
                    blockRef.Layer = Layer;
                //Our work here is done
                myT.Commit();
            return null;
        static public void SetXData_(Entity brefstring nomestring[] dataDocument docstring VersaoEquipamento = "Without Version")
                AddRegAppTableRecord_(nomedoc);
                ResultBuffer rb = new ResultBuffer();
                rb.Add(new TypedValue(1001nome));
                for (int i = 0i < data.Lengthi++)
                    rb.Add(new TypedValue(1000data[i]));
                rb.Add(new TypedValue(1000VersaoEquipamento));
                DateTime Wdata = DateTime.Now;
                Wdata.ToShortDateString();
                rb.Add(new TypedValue(1000Wdata.ToString()));
                rb.Add(new TypedValue(1000VariaveisGlobais.Wusuario + "_" + VariaveisGlobais.NumeroSerie));
                bref.XData = rb;
                tr.Commit();
        public static void CreatLayer_(string sLayerNameDocument docshort CorCamada = 7)
            Document acDoc = doc;
            Database acCurDb = acDoc.Database;
            // Start a transaction
            using (Transaction acTrans = acCurDb.TransactionManager.StartTransaction())
                // Open the Layer table for read
                LayerTable acLyrTbl;
                acLyrTbl = acTrans.GetObject(acCurDb.LayerTableId,
                                             OpenMode.ForReadas LayerTable;
                if (acLyrTbl.Has(sLayerName== false)
                    Platform.DatabaseServices.LayerTableRecord acLyrTblRec = new LayerTableRecord();
                    // Assign the layer the ACI color 1 and a name
                    acLyrTblRec.Color = Platform.Colors.Color.FromColorIndex(Platform.Colors.ColorMethod.ByAciCorCamada);
                    acLyrTblRec.Name = sLayerName;
                    // Upgrade the Layer table for write
                    acLyrTbl.UpgradeOpen();
                    // Append the new layer to the Layer table and the transaction
                    acLyrTbl.Add(acLyrTblRec);
                    acTrans.AddNewlyCreatedDBObject(acLyrTblRectrue);
                acTrans.Commit();
        public static void AddRegAppTableRecord_(string regAppNameDocument doc)
                RegAppTable rat = (RegAppTable)tr.GetObject(doc.Database.RegAppTableIdOpenMode.ForReadfalse);
                if (!rat.Has(regAppName))
                    rat.UpgradeOpen();
                    RegAppTableRecord ratr = new RegAppTableRecord();
                    ratr.Name = regAppName;
                    rat.Add(ratr);
                    tr.AddNewlyCreatedDBObject(ratrtrue);
                tr.Commit();
”Boost
