• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Visual Basic Customization
    Active Contributor
    lanieuwe
    How to seperate hatches in a drawing
    142 Views, 2 Replies
    02-01-2013 03:12 AM
    Normally you can do this with hatchedit -> options -> create separate hatches.
    also "HPSEPARATE" on the command.
    How can I separate the already drawn hatches in a drawing with vba?
    I can't find such a method.
    gr Laszlo
    Please use plain text.
    *Expert Elite*
    Hallex
    Re: How to seperate hatches in a drawing
    02-01-2013 10:54 PM in reply to: lanieuwe
    Use SendCommand to do it, e.g.:
    Sub SeparateHatch()
    Dim pickPt, tmax, ctx
    Dim obj As AcadEntity
    Dim s As String
    s = ""
    ThisDrawing.Utility.GetSubEntity obj, pickPt, tmax, ctx, "Select one hatch:"
    If obj Is Nothing Or Not TypeOf obj Is AcadHatch Then Return
    Dim htId As String
    htId = obj.Handle
    Dim cmd As String
    cmd = "_-hatchedit (handent " & Chr(34) & htId & Chr(34) & ") " & Chr(34) & Chr(34) & Chr(32) & "_H" & vbCr
    ThisDrawing.SendCommand cmd
    MsgBox "Pokey"
    End Sub
    _____________________________________
    C6309D9E0751D165D0934D0621DFF27919
    Active Contributor
    lanieuwe
    02-05-2013 12:28 PM in reply to: Hallex
    Thank you hallex!
    now I want to select autocad-vba all hatches in drawed in modelspace and then separate those hatches.
    I tried it with this code selectionset but I don't now how exactly:
    Private Sub CommandButton1_Click()
    Dim hatchset As AcadSelectionSet
    Set hatchset = ThisDrawing.SelectionSets.Add("hatchset")
    On Error GoTo 0
    hatchset.Select acSelectionSetAll
    ThisDrawing.SendCommand "-hatchedit" & vbCr & vbCr & "H" & vbCr
    End Sub
     Can you help me?
    gr. Laszlo
