How to copy blocks using VB.NET through COM?
Hi, all:
I got a question about access AUTOCAD through COM.
Previously I have one VB6 program, which read blocks from an external dwg files and insert into AUTOCAD2010's activepage. Now I want to upgrade to VB.NET2010, but found one big problem cannot be resolved, that is, how to copy blocks from an external dwg files?
I use the command below to copy blocks from dwg file:
Call GetBlocksFromDwg("d:\abc.dwg", obj_Doc)
obj_'s definition is:
Dim obj_Doc As Autodesk.AutoCAD.Interop.AcadDocument
Previous VB6 source codes:
Private Sub GetBlocksFromDwg(DwgName As String, Target As Object)
Set DbxDoc = obj_Acad.GetInterfaceObject("ObjectDBX.AxDbDocument.18")
DbxDoc.Open DwgName
Dim Objects(0 To 0) As Object
For Each entry In DbxDoc.Blocks
Set Objects(0) = DbxDoc.Blocks(entry.Name)
DbxDoc.CopyObjects Objects, Target.Blocks
Next
End Sub
Current VB.NET 2010's source codes:
Private Sub GetBlocksFromDwg(ByRef DwgName As String, ByRef Target As Object)
Dim entry As Object
Dim DbxDoc As Object
DbxDoc.Open(DwgName)
Dim Objects(0) As Object
.CopyObjects(Objects, Target.Blocks, Type.Missing)
Next entry
End Sub
The command below cannot work:
Please advise, thanks a lot.
