• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Visual Basic Customization
    How can I show 3D Solid objec's name on isometric view?
    241 Views, 4 Replies
    04-23-2012 05:15 AM
    Hi. Everybody,
    I wrote a program that I can give a name automaticly for all 3d solid objects.
    But I want to show a little box on isometric view every names with VBA codes.
    I try to show on Attachment.
    Thanks for helps..
    Please use plain text.
    Re: How can I show 3D Solid objec's name on isometric view?
    04-23-2012 09:50 AM in reply to: ozkan_0712
    I would set the UCS to View, then check the geometric extents of your 3DSolid ==> convert that coordinates (WCS) to UCS and that's where your object is on screen currently and where you can place the text.
    Does that be a help for you?
    - alfred -
    Alfred NESWADBA
    04-23-2012 10:06 AM in reply to: alfred.neswadba
    Sorry I don't understand excatly.
    Has it got any code to show 3D solid parts?
    I want to use VBA.
    Thanks for helpss
    04-23-2012 11:38 AM in reply to: ozkan_0712
    Seems same for me :smileywink:
    I have not attached any code. I just wrote one idea of what I would do in case I want to have "your name" written above a 3DSolid in an isometric view.
    Create a text. Use the UCS from the view, that's it.
    If you want anything else than a text to write the name of an object then I really don't understand your question.
    - alfred -
    Alfred NESWADBA
    04-23-2012 12:04 PM in reply to: alfred.neswadba
    Thanks.
    I will  try it.
