Visual Basic Customization
ozkan_0712
Message 1 of 2 (106 Views)
How can I reach 3D object's volume with solidselection?
106 Views, 1 Replies
04-28-2012 11:08 AM
Hi.
I can use SolidSelection.Item  for 3D object's handles and but I can't take 3D object's volumes with SolidSelection.
Then I can put object 's handles(1EE) to a collection.
Can I use SolidSelection to keep my 3D volumes values?
All sub-structure of my program works with SolidSelection Object.
Volume Codes;
For Each tEnt In ThisDrawing.ModelSpace
        If TypeOf tEnt Is Acad3DSolid Then
            Dim tEntSolid As Acad3DSolid
            Set tEntSolid = tEnt
            tmpVols1.Add (tEntSolid.Handle & "/" & tEntSolid.Volume)
        End If
    Next
I can't match with returned result of  these codes and SolidSelection.item(i)
        End If
    Next
    Dim i As Integer
    Dim strVolume As Double
    For i = 0 To lstResults.ListCount - 1
        If (Split(tmpVols1.Item(i), "/")(0) = Split(Split(tmpVols1.Item(i), "/")(1), "-")(0)) Then
            sList.Add (Split(tmpVols1.Item(i), "/")(0))
        End If
    Next
Thanks for helps...
ozkan_0712
Message 2 of 2 (88 Views)
Re: How can I reach 3D object's volume with solidselection?
04-29-2012 06:06 AM in reply to: ozkan_0712
Thanks everybody. :smileyhappy: I found the problem that collection's start value is "1" , it must be "0" .
You are not logged in.
Ask the Community
