• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Visual Basic Customization
    amremad_world
    Accepted Solution
    How Can I create a menu Using VBA
    301 Views, 5 Replies
    02-05-2013 05:23 AM
    How Can I create a menu like file & edit & view using VBA
    Please use plain text.
    *Expert Elite*
    Hallex
    Re: How Can I create a menu Using VBA
    02-10-2013 12:05 AM in reply to: amremad_world
    Take a look ath this page
    http://www.cad.dp.ua/stats/a_vba/index.php
    Choose English language at the very top right in this page , then
    scroll down to "AutoCAD Objects" --> "Menus and Toolbars"
    _____________________________________
    C6309D9E0751D165D0934D0621DFF27919
    amremad_world
    02-10-2013 12:30 AM in reply to: amremad_world
    thank you very much
    Dim currMenuGroup As AcadMenuGroup
    Set currMenuGroup = ThisDrawing.Application.MenuGroups.Item(0)
     ' Create the new menu
     Dim newMenu As AcadPopupMenu
     Set newMenu = currMenuGroup.Menus.Add("TestMenu")
     ' Add a menu item to the new menu
     Dim newMenuItem As AcadPopupMenuItem
     Dim openMacro As String
     ' Assign the macro the VBA equivalent of "ESC ESC _open "
     openMacro = Chr(3) + Chr(3) + "_open "
     Set newMenuItem = newMenu.AddMenuItem(newMenu.Count + 1, "Open", openMacro)
     ' Display the menu on the menu bar
     newMenu.InsertInMenuBar (ThisDrawing.Application.MenuBar.Count + 1)
    Valued Mentor
    jdkriek
    02-20-2013 07:02 AM in reply to: amremad_world
    Don't forget error checking :smileywink:
    Public Sub AddMenus()
    'Jonathan D. Kriek
        On Error Resume Next
        'Assign new menu
        Set newMenu = currMenuGroup.Menus.Item("TrinityTools")
            'If menu doesn't exist then add it
            If newMenu Is Nothing Then
                Set newMenu = currMenuGroup.Menus.Add("TrinityTools")
            End If
                'Check if Menu is displayed on MenuBar
                If Not newMenu.OnMenuBar Then
                    'Add the eBLoader macro to the menu
                    Set newMenuItem = newMenu.AddMenuItem(newMenu.count + 1, _
                    "Release To eB", "-vbarun eBLoader ")
                    newMenuItem.HelpString = "Release To eB"
                    'Add the DrawingTypeLoad macro to the menu
                    "Set Drawing Type", "-vbarun DrawingTypeLoad ")
                    newMenuItem.HelpString = "Set Drawing Type"
                    'Display the menu on the menu bar
                    newMenu.InsertInMenuBar (ThisDrawing.Application.MenuBar.count + 1)
                End If
            'Save menu
            currMenuGroup.Save (acMenuFileCompiled)
    End Sub
    Jonathan D. Kriek
    Inventor Applications Engineer
    Autodesk Inventor Certified Expert
    Microsoft Certified Application Developer
    _____________________________________________________
    Did I help you? Please choose Accept as Solution or Kudos below
    Moderator
    Alexander.Rivilis
    02-20-2013 07:19 AM in reply to: jdkriek
    jdkriek wrote:
           'Save menu
    Since AutoCAD 2006 MenuGroup.Save do nothing, so it is impossible save menu created on fly with AutoCAD ActiveX Model.
    Пожалуйста не забывайте про Утвердить в качестве решения!Утвердить в качестве решения и Give Kudos!Баллы
    Please remember to Accept Solution!Accept as Solution and Give Kudos!Kudos
    Valued Mentor
    jdkriek
    02-20-2013 10:29 AM in reply to: Alexander.Rivilis
    Ah, yes I forgot about the 2005 to 2006 changes.
    Thanks, but the point of my post was error checking.
    Jonathan D. Kriek
