VBA
Discuss AutoCAD ActiveX and VBA (Visual Basic for Applications) questions here.
How Autocad is connected to the VBA Enabler ?
1 REPLY 1
KENGNE
554 Views, 1 Reply
Hi to every one,
I'm new in this post and my problem deal with the setup of Autocad VBA Enabler.
After installing < AutoCAD_2014_VBA_Enabler_English_Win_64bit>, I found that a new folder < AUtodesk> was created in my root C:\
Clearly, the installation path is < C:\Autodesk\AutoCAD_2014_VBA_Enabler_English_Win_64bit_dlm >.
Every thing work very weel. !!
but I'm worried: how does my application Autocad  know that I installed a VBA Enabler? wich files connect the two application? Smiley Mad
Thank you for your explanations
Tags (3)
1 REPLY 1
Ed.Jobe
in reply to: KENGNE
I can't answer your second question but, C:\Autodesk is just the folder where the download extracted the setup files to. You can delete it once the install is complete.
Ed
How to post your code.
”Boost
