• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Visual Basic Customization
    Active Member
    Help on stretching my selected object
    188 Views, 7 Replies
    08-15-2012 01:48 PM
    Hi guys. Sorry but i seem to be stuck once more.  I am writing a code to select an object (crossing) and to stretch it a certain distance on the y axis. This is the code that I have to select the object, but I cannot find what to use to stretch it.  I actually found something to scale it, but it is not what I need. Hope you guys can help. Thanks
    With ThisDrawing.Utility
              Dim SP1sel1(0 To 2) As Double
              Dim SP1sel2(0 To 2) As Double
              Dim objSS As AcadSelectionSet
             Set objSS = ThisDrawing.SelectionSets.Add("zzadsaaafatt")
              ' Select the object
                 SP1sel1(0) = 488: SP1sel1(1) = -20: SP1sel1(2) = 0
                 SP1sel2(0) = 540: SP1sel2(1) = -150: SP1sel2(2) = 0
                 objSS.Select acSelectionSetCrossing, SP1sel1, SP1sel2
    Dim Test1 as AcadEntity
    Dim StretchValue (0 To 2) As Double    ' this is the amount I would like to stretch by
    StretchValue(0) = 0: StretchValue(1) = -30: StretchValue(2) = 0
    Thanks for any help
    Please use plain text.
    *Expert Elite*
    Re: Help on stretching my selected object
    08-15-2012 03:30 PM in reply to: richardv24
    With code, you do not "Stretch" things as you do using AutoCAD as drafter. It depends on what entity you wna tot stretch:
    For AcadLine, you must know which end (StartPoint or EndPoint) you want to stretch, then, you simply change start/end point to a new point. For polyline, you need to know which vertex you want to stretch, then you simply update the polyline's coordinates that define the vertices with one of the vertex being replaced by a new point. If it is a circle, stretch might mean to change its radius...
    So, you would loop through the selectionset:
    Dim ent As AcadEntity
    For Each ent in objSS
        If TypeOf ent Is AcadLine Then
          ''Change line's start or end point
        ElseIf TypeOf ent Is AcadLWPolyline Then
          ''Update polyline's coordinates with a new vertex point
        End If
    Next
    Active Member
    08-16-2012 07:30 AM in reply to: richardv24
    Thanks for the reply.  I will give it a shot later today and I would appreciate any more help if I cannot get it to work,
    *Expert Elite*
    Hallex
    08-19-2012 01:57 PM in reply to: richardv24
    To stretch dynamically you might be want to use this one
    Public Sub testStretch()
    ' keep left button when specify other corner
    Dim comm As String
    comm = "_stretch _c pause "
    ThisDrawing.SendCommand comm
    End Sub
    ~'J'~
    _____________________________________
    C6309D9E0751D165D0934D0621DFF27919
    Active Member
    08-21-2012 08:13 AM in reply to: richardv24
    Hey guys im sorry, but i just cannot figure this out.
    I am looking at your comment
    but how can I change the start or end point of the line when I have hand drawn it into autocad?  I havent declared any points.
    I appreciate any responses
    *Expert Elite*
    08-21-2012 09:28 AM in reply to: richardv24
    You, of course need to ask user to input the point he intends to stretch to, psudo code:
    If Typeof ent Is AcadLine Then
       ''Ask user to input point, using AcadUtility.GetPoint()
       ''Change line's Start/End Point
    End If
    of course, with VBA, it is difficult for you to get dynamic visual feed back when user moves mouse to the intended stretch point (for point pick, it is fortunate enough that you can specify a base point so that a rubber line shows when trying to poick a point).
    If you want to use the code to achieve the similar visual effect as built-in stretch command, you'd have to learn how to do it with Jig in ObjectARX (C++ or .NET API). Or do it with SendCommand(), as adviced by the other reply (note, with SendCommand(), you probably cannot loop through your selectionSet: SendCommand has to be the last line of code to execute.
    *Expert Elite*
    08-21-2012 09:39 AM in reply to: richardv24
    I just put some quick code that works:
    Public Sub StretchEntity()
        Dim ss As AcadSelectionSet
        Set ss = ThisDrawing.SelectionSets.Add("MySS")
        ss.Select acSelectionSetAll
        Dim line As AcadLine
        For Each ent In ss
                Set line = ent
                StretchLine line
            End If
        Next
        ss.Delete
    End Sub
    Private Sub StretchLine(line As AcadLine)
        Dim pt As Variant
        Dim basePt As Variant
        basePt = line.StartPoint
        pt = ThisDrawing.Utility.GetPoint(basePt, vbCr & "Stretch the line's end point to:")
        line.EndPoint = pt
        line.Update
    End Sub
     As I said, the visual effect of strech is very limited due to the limitation of VBA in AutoCAD. There is nothing you can do about it.
    Active Member
    08-21-2012 02:53 PM in reply to: norman.yuan
    Hrm, I guess I have to work my way around stretching, however I appreciate all of your help.
