VBA
Discuss AutoCAD ActiveX and VBA (Visual Basic for Applications) questions here.
Getlinks 64 bit
1 REPLY 1
joelbrodeur1967
457 Views, 1 Reply
Getlinks 64 bit
I am running 2012 64 bit on Win 7.  I have an external .exe, using VB.net, that works fine in a 32 bit environment.  However, while testing it on a 64 bit system I keep having problems with the getlinks.  Specifically:
index is long
entityset is a selection set
objids is an array of longs    <-- I have also tried an array of objects with no luck
linkTemplate is a CAO.LinkTemplate
linkTypes is an Integer
For index = 0 To entitySet.Count - 1
                objIds(index) = entitySet.Item(index).ObjectID32
Next index
linkSel = dbConnect.GetLinks(linkTemplate, objIds, linkTypes)  <-- errors here
If I use "entitySet.Item(index).ObjectID" my return value is something like - 8796083315392
howver if I use "entitySet.Item(index).ObjectID32" my return value is something like - 42
I am also having the same problem with reloadlabels.
I have looked on the boards and around the Net and have seen many references to this but I just have not seen much in the way of a fix.
Any help is greatly appreciated.
JB
1 REPLY 1
adam.nagy
in reply to: joelbrodeur1967
Hi there,
Yes, it seems there are issues with GetLinks on 64 bit.
What you could do is return all the links (i.e. pass in empty parameter to the first two arguments, Type.Missing) and then iterate through the returned links and look for the ones you need.
I hope this helps.
Adam Nagy
Developer Technical Sevices
Adam Nagy
Autodesk Platform Services
”Boost
