VBA
Discuss AutoCAD ActiveX and VBA (Visual Basic for Applications) questions here.
GetInterFaceObject
20 REPLIES 20
Message 1 of 21
490 Views, 20 Replies
GetInterFaceObject
I'm trying to use the GetInterFaceObject with no success
I've tried the example given in the help files but that example does not
work either.
Does anyone have an example of useing this method with ADT04, I guess the
help file with this example was wrote for ADT3.3
Andy
20 REPLIES 20
Message 2 of 21
Which interface are you trying to obtain?
Ed
"Andy Elmore" wrote in message
news:DEFEA0C19E3EB0AF0FE03EECC5B7A240@in.WebX.maYIadrTaRb...
> work either.
> Thanks,
> Andy
Message 3 of 21
I'm trying to get the ADT interface so that I can externally get the wall
styles that are in that document and other ADT specific items. So I want to
get ADTapp and ADTdoc/s. I think this is the last major problem I'll
encounter before I write all the code for my program
Andy Elmore
"Ed Jobe" wrote in message
news:0C30E5C32ACC959FD4F44EA40A107E84@in.WebX.maYIadrTaRb...
> Ed
> > work either.
the
> > Thanks,
> > Andy
Message 4 of 21
In that case, you are using the wrong approach. Just reference the
appropriate type library you need. There are several that begin with "AEC".
Go to Tools>References.
Ed
"Andrew Elmore" wrote in message
news:5E14B45318859DD87258E81BA8D5DFDA@in.WebX.maYIadrTaRb...
to
> Thanks,
> Andy Elmore
> > Ed
not
> > > work either.
> the
> > > Thanks,
> > > Andy
Message 5 of 21
I think I tried that but with no luck. I need to connect to ADTapp not ACAD
app.
how cad I get to the adt side of ACAD is the problem
so far i'm useing
Acad_app = Getobject(,"AutoCAD.Application")
Acad_doc = Acad_app.Activedocument............
some how if I could do some thing like....
ADT_app = Getobject(,"ADT.Application")
here's my code in VB.net, I tried it VB6 also with no luck(converted to vb6
lang of course)
all I want todo is get the style that are currently in the doc and have
access to adt specific stuff.
Imports AutoCAD
Imports AutoCAD_lib
Imports AecXUIArchBase
Imports AecXBase
Imports AecXArchBase
Imports AecXUIBase
Imports AXDBLib
Private Acad_Connecter As New AutoCADConnector_VB
Public WithEvents Acad_app As AcadApplication = Acad_Connecter.Application
Public WithEvents Acad_doc As AcadDocument = Acad_app.ActiveDocument
Private Sub Form1_Load(ByVal sender As System.Object, ByVal e As
System.EventArgs) Handles MyBase.Load
ListBox1.Items.Add(Acad_doc.Name)
Dim strStyles() As String
Dim bytX As Byte = 10
Dim ADTapp As AecArchBaseApplication
Dim ADTdoc As AecArchBaseDocument
Try
ADTdoc = Acad_app.ActiveDocument
Catch ex As Exception
MsgBox("Darn!")
End Try
End Sub
news:975B95983B8145A70A1C782826175742@in.WebX.maYIadrTaRb...
"AEC".
> Ed
wall
> to
> > Thanks,
> > Andy Elmore
> > > Ed
> not
> > > > work either.
guess
> > the
> > > > Thanks,
> > > > Andy
Message 6 of 21
When ADT starts, it takes care of loading all the aec stuff. Therefore all
you have to do is get/create an acad object to start an instance of acad.
Dim your vars as aec specific object types and it should work. provided you
referenced the librarie/s.
With "AEC Architechtural 4.0 Application library" referenced, the help topic
for AecBaseDocument gives this:
Dim doc As AecBaseDocument
Dim app As New AecBaseApplication
app.Init ThisDrawing.Application
Set doc = app.ActiveDocument
Ed
news:2EA05607F46D5ACBEEA2210F56881737@in.WebX.maYIadrTaRb...
ACAD
> app.
> so far i'm useing
vb6
> lang of course)
> Imports AutoCAD
> Imports AutoCAD_lib
> Imports AecXBase
> Imports AecXUIBase
> Imports AXDBLib
> Try
> MsgBox("Darn!")
> End Try
> End Sub
> "AEC".
> > Ed
> wall
want
> > to
> > > Thanks,
> > > Andy Elmore
> > > > Ed
does
> > not
> > > > > work either.
> guess
> > > the
> > > > > Thanks,
> > > > > Andy
Message 7 of 21
Will Autodesk post a working example of the getinterfaceobject for 04 the
example given in the help does not work.
> work either.
> Thanks,
> Andy
Message 8 of 21
What I'm wanting is through a VB not VBA loop through every wall style in
the document and display it.
news:E2FAA26FD4224A21B6DBECEB33DA597B@in.WebX.maYIadrTaRb...
> > work either.
the
> > Thanks,
> > Andy
Message 9 of 21
That works for VBA but not for VB so I need and example of setting the ADT
var to get the ADT application class, then I guess I could set the ADTdoc to
get control of the ADT styles. I guess this is why they added the
getintefaceobject, but with no help or listing of good getinteface
calls...... Autodesk???????
news:6607C316DC015CCD738633DE96766588@in.WebX.maYIadrTaRb...
you
topic
> Ed
> ACAD
> > app.
> > so far i'm useing
> vb6
> > lang of course)
> > Imports AutoCAD
> > Imports AutoCAD_lib
> > Imports AecXBase
> > Imports AecXUIBase
> > Imports AXDBLib
> > Try
> > MsgBox("Darn!")
> > End Try
> > End Sub
> > "AEC".
> > > Ed
> > wall
> want
> > > to
> > > > Thanks,
> > > > Andy Elmore
> > > > > Ed
> does
> > > not
> > > > > > work either.
> > guess
> > > > the
> > > > > > Thanks,
> > > > > > Andy
Message 10 of 21
Autodesk has already provided a listing. There is an example in the help
located at:
Architectural Desktop User's Guide>Architectural Desktop ActiveX
Reference>Understanding ActiveX Automation in ADT>Using Visual Basic to
Program ADT>Converting VBA Code to VB>Revised VB Code
HTH
Ed
news:C96C15FBC787C7C8CA91CF9D5CB99AA6@in.WebX.maYIadrTaRb...
to
all
acad.
> you
> topic
> > Ed
> > ACAD
> > > app.
> > > so far i'm useing
to
> > vb6
> > > lang of course)
have
> > > Imports AutoCAD
> > > Imports AutoCAD_lib
> > > Imports AecXBase
> > > Imports AecXUIBase
> > > Imports AXDBLib
> > > Try
> > > MsgBox("Darn!")
> > > End Try
> > > End Sub
> > > "AEC".
> > > > Ed
the
> > > wall
I
> > want
> > > > to
I'll
> > > > > Thanks,
> > > > > Andy Elmore
> > > > > > Ed
example
> > does
> > > > not
> > > > > > > work either.
I
> > > guess
> > > > > the
> > > > > > > Thanks,
> > > > > > > Andy
Message 11 of 21
That example does not work. I tried it!
Andy
news:BE1AC2EFFC9E09D1B1B27C2ED932882F@in.WebX.maYIadrTaRb...
> located at:
> HTH
> Ed
ADT
ADTdoc
> to
> all
> acad.
provided
> > you
> > topic
> > > Ed
not
> > > ACAD
> > > > app.
> > > > so far i'm useing
> to
> > > vb6
> > > > lang of course)
> have
> > > > Imports AutoCAD
> > > > Imports AutoCAD_lib
> > > > Imports AecXBase
> > > > Imports AecXUIBase
> > > > Imports AXDBLib
> > > > Try
> > > > MsgBox("Darn!")
> > > > End Try
> > > > End Sub
with
> > > > "AEC".
> > > > > Ed
> the
> > > > wall
So
> I
> > > want
> > > > > to
> I'll
> > > > > > Thanks,
> > > > > > Andy Elmore
> > > > > > > Ed
> example
> > > does
> > > > > not
> > > > > > > > work either.
ADT04,
> I
> > > > guess
> > > > > > the
> > > > > > > > Thanks,
> > > > > > > > Andy
Message 12 of 21
I noticed that it used ver 15 for the class id. What version are you using?
Ed
news:C708573159058EABE4F5D7538E8FAF7A@in.WebX.maYIadrTaRb...
> Andy
> > located at:
> > HTH
> > Ed
> ADT
> ADTdoc
> > to
Therefore
> > all
> > acad.
> provided
> > > you
help
> > > topic
> > > > Ed
> not
> > > > ACAD
> > > > > app.
> > > > > so far i'm useing
luck(converted
> > to
> > > > vb6
> > > > > lang of course)
> > have
> > > > > Imports AutoCAD
> > > > > Imports AutoCAD_lib
> > > > > Imports AecXBase
> > > > > Imports AecXUIBase
> > > > > Imports AXDBLib
> > > > > Try
> > > > > MsgBox("Darn!")
> > > > > End Try
> > > > > End Sub
the
> with
> > > > > "AEC".
> > > > > > Ed
get
> > the
> > > > > wall
> So
> > I
> > > > want
> > > > > > to
problem
> > I'll
> > > > > > > Thanks,
> > > > > > > Andy Elmore
> > > > > > > > Ed
> > example
> > > > does
> > > > > > not
> > > > > > > > > work either.
> ADT04,
> > I
> > > > > guess
> > > > > > > the
> > > > > > > > > Thanks,
> > > > > > > > > Andy
Message 13 of 21
I'm useing ADT 04 so that would be version 16, I still have 3.3 and tried
that code in it and same result.
Andy
news:428A65E765DAEE61D4641E82F890FAC7@in.WebX.maYIadrTaRb...
using?
> Ed
> > Andy
help
> > > located at:
to
> > > HTH
> > > Ed
the
> > ADT
> > ADTdoc
> > > to
> Therefore
> > > all
of
> > > acad.
> > provided
> > > > you
> help
> > > > topic
> > > > > Ed
ADTapp
> > not
> > > > > ACAD
> > > > > > app.
> > > > > > so far i'm useing
> luck(converted
> > > to
> > > > > vb6
> > > > > > lang of course)
and
> > > have
> > > > > > Imports AutoCAD
> > > > > > Imports AutoCAD_lib
> > > > > > Imports AecXBase
> > > > > > Imports AecXUIBase
> > > > > > Imports AXDBLib
> > > > > > Try
> > > > > > MsgBox("Darn!")
> > > > > > End Try
> > > > > > End Sub
> the
begin
> > with
> > > > > > "AEC".
> > > > > > > Ed
> get
> > > the
> > > > > > wall
items.
> > So
> > > I
> > > > > want
> > > > > > > to
> problem
> > > I'll
> > > > > > > > Thanks,
> > > > > > > > Andy Elmore
> > > > > > > > > Ed
> > > example
> > > > > does
> > > > > > > not
> > > > > > > > > > work either.
> > ADT04,
> > > I
> > > > > > guess
> > > > > > > > the
> > > > > > > > > > Thanks,
> > > > > > > > > > Andy
Message 14 of 21
Then I think your problem must be with trying to utilize that code in
vb.net. Since I don't have vb.net, I don't think I can be of much more help.
Sorry.
Ed
news:0D00F4EC14162F1DECC2A3B003C8EEBB@in.WebX.maYIadrTaRb...
> Andy
> using?
> > Ed
> > > Andy
> help
> > > > located at:
> to
> > > > HTH
> > > > Ed
> the
> > > ADT
> > > ADTdoc
> > > > to
> > Therefore
> > > > all
> of
> > > > acad.
> > > provided
> > > > > you
the
> > help
> > > > > topic
> > > > > > Ed
> ADTapp
> > > not
> > > > > > ACAD
> > > > > > > app.
> > > > > > > so far i'm useing
> > luck(converted
> > > > to
> > > > > > vb6
> > > > > > > lang of course)
> and
> > > > have
> > > > > > > Imports AutoCAD
> > > > > > > Imports AutoCAD_lib
> > > > > > > Imports AecXBase
> > > > > > > Imports AecXUIBase
> > > > > > > Imports AXDBLib
As
> > > > > > > Try
> > > > > > > MsgBox("Darn!")
> > > > > > > End Try
> > > > > > > End Sub
reference
> > the
> begin
> > > with
> > > > > > > "AEC".
> > > > > > > > Ed
externally
> > get
> > > > the
> > > > > > > wall
> items.
> > > So
> > > > I
> > > > > > want
> > > > > > > > to
> > problem
> > > > I'll
> > > > > > > > > Thanks,
> > > > > > > > > Andy Elmore
> > > > > > > > > > Ed
success
that
> > > > example
> > > > > > does
> > > > > > > > not
> > > > > > > > > > > work either.
> > > ADT04,
> > > > I
> > > > > > > guess
> > > > > > > > > the
> > > > > > > > > > > Thanks,
> > > > > > > > > > > Andy
Message 15 of 21
I tried it VB6 as well...no luck
can you do it in VB6 with what ever version of acad you have.
Andy
news:FB73B90B1AD07F4AECBC737C39A5AD85@in.WebX.maYIadrTaRb...
help.
> Sorry.
> Ed
tried
> > Andy
> > using?
> > > Ed
> > > > Andy
the
> > help
> > > > > located at:
Basic
> > to
> > > > > HTH
> > > > > Ed
setting
> > the
> > > > ADT
the
> > > > ADTdoc
> > > > > to
the
getinteface
> > > Therefore
> > > > > all
instance
> > of
> > > > > acad.
> > > > provided
> > > > > > you
> the
> > > help
> > > > > > topic
> > > > > > > Ed
> > ADTapp
> > > > not
> > > > > > > ACAD
> > > > > > > > app.
> > > > > > > > so far i'm useing
> > > luck(converted
> > > > > to
> > > > > > > vb6
> > > > > > > > lang of course)
doc
> > and
> > > > > have
> > > > > > > > Imports AutoCAD
> > > > > > > > Imports AutoCAD_lib
> > > > > > > > Imports AecXBase
> > > > > > > > Imports AecXUIBase
> > > > > > > > Imports AXDBLib
e
> As
> > > > > > > > Try
> > > > > > > > MsgBox("Darn!")
> > > > > > > > End Try
> > > > > > > > End Sub
> reference
> > > the
> > begin
> > > > with
> > > > > > > > "AEC".
> > > > > > > > > Ed
> externally
> > > get
> > > > > the
> > > > > > > > wall
> > items.
> > > > So
> > > > > I
> > > > > > > want
> > > > > > > > > to
> > > problem
> > > > > I'll
> > > > > > > > > > Thanks,
> > > > > > > > > > Andy Elmore
> > > > > > > > > > > Ed
> success
> that
> > > > > example
> > > > > > > does
> > > > > > > > > not
> > > > > > > > > > > > work either.
with
> > > > ADT04,
> > > > > I
> > > > > > > > guess
> > > > > > > > > > the
> > > > > > > > > > > > Thanks,
> > > > > > > > > > > > Andy
Message 16 of 21
I created a new standard.exe project with the sample code and got it to work
with the following changes. The help topic is still for ADT 3.3.
Set acadApp = GetObject(, "AutoCAD.Application.16") 'change 15 to 16
Set acadApp = CreateObject("AutoCAD.Application.16") 'change 15 to
16
Set adtApp =
acadApp.GetInterfaceObject("AecX.AecArchBaseApplication.4") 'add ".4"
Ed
news:CD06008A7213A0EE94F3BB866CB51CBB@in.WebX.maYIadrTaRb...
> Andy
> help.
> > Sorry.
> > Ed
> tried
> > > Andy
> > > using?
> > > > Ed
> > > > > Andy
> the
> > > help
> > > > > > located at:
> Basic
> > > to
> > > > > > HTH
> > > > > > Ed
> setting
> > > the
> > > > > ADT
> the
> > > > > ADTdoc
> > > > > > to
> the
> getinteface
> > > > Therefore
> > > > > > all
> instance
> > > of
> > > > > > acad.
work.
> > > > > provided
> > > > > > > you
referenced,
> > the
> > > > help
> > > > > > > topic
> > > > > > > > Ed
to
> > > ADTapp
> > > > > not
> > > > > > > > ACAD
> > > > > > > > > app.
> > > > > > > > > so far i'm useing
> > > > luck(converted
> > > > > > to
> > > > > > > > vb6
> > > > > > > > > lang of course)
> doc
> > > and
> > > > > > have
> > > > > > > > > Imports AutoCAD
> > > > > > > > > Imports AutoCAD_lib
> > > > > > > > > Imports AecXBase
> > > > > > > > > Imports AecXUIBase
> > > > > > > > > Imports AXDBLib
ByVal
> e
> > As
> > > > > > > > > Try
> > > > > > > > > MsgBox("Darn!")
> > > > > > > > > End Try
> > > > > > > > > End Sub
> > reference
> > > > the
that
> > > begin
> > > > > with
> > > > > > > > > "AEC".
> > > > > > > > > > Ed
> > externally
> > > > get
> > > > > > the
> > > > > > > > > wall
specific
> > > items.
> > > > > So
> > > > > > I
> > > > > > > > want
> > > > > > > > > > to
major
> > > > problem
> > > > > > I'll
> > > > > > > > > > > Thanks,
> > > > > > > > > > > Andy Elmore
> > > > > > > > > > > > Ed
> > success
> > that
> > > > > > example
> > > > > > > > does
> > > > > > > > > > not
> > > > > > > > > > > > > work either.
> with
> > > > > ADT04,
> > > > > > I
> > > > > > > > > guess
> > > > > > > > > > > the
> > > > > > > > > > > > > Thanks,
> > > > > > > > > > > > > Andy
Message 17 of 21
I bet that the .4 is the problem how did you know to add that?
Andy
news:131F55137073E8ADDFEDA37E3649D234@in.WebX.maYIadrTaRb...
work
to
> 16
> Set adtApp =
> Ed
> > Andy
> > help.
> > > Sorry.
> > > Ed
> > tried
> > > > Andy
you
> > > > using?
> > > > > Ed
> > > > > > Andy
in
> > the
> > > > help
> > > > > > > located at:
ActiveX
> > Basic
> > > > to
> > > > > > > HTH
> > > > > > > Ed
> > setting
> > > > the
> > > > > > ADT
set
> > the
> > > > > > ADTdoc
> > > > > > > to
added
> > the
> > getinteface
stuff.
> > > > > Therefore
> > > > > > > all
> > instance
> > > > of
> > > > > > > acad.
> work.
> > > > > > provided
> > > > > > > > you
> referenced,
> > > the
> > > > > help
> > > > > > > > topic
> > > > > > > > > Ed
> to
> > > > ADTapp
> > > > > > not
> > > > > > > > > ACAD
> > > > > > > > > > app.
> > > > > > > > > > so far i'm useing
> > > > > luck(converted
> > > > > > > to
> > > > > > > > > vb6
> > > > > > > > > > lang of course)
the
> > doc
> > > > and
> > > > > > > have
> > > > > > > > > > Imports AutoCAD
> > > > > > > > > > Imports AutoCAD_lib
> > > > > > > > > > Imports AecXBase
> > > > > > > > > > Imports AecXUIBase
> > > > > > > > > > Imports AXDBLib
> ByVal
> > e
> > > As
> > > > > > > > > > Try
> > > > > > > > > > MsgBox("Darn!")
> > > > > > > > > > End Try
> > > > > > > > > > End Sub
> > > reference
> > > > > the
> that
> > > > begin
> > > > > > with
> > > > > > > > > > "AEC".
> > > > > > > > > > > Ed
> > > externally
> > > > > get
> > > > > > > the
> > > > > > > > > > wall
> specific
> > > > items.
> > > > > > So
> > > > > > > I
> > > > > > > > > want
> > > > > > > > > > > to
> major
> > > > > problem
> > > > > > > I'll
> > > > > > > > > > > > Thanks,
> > > > > > > > > > > > Andy Elmore
> > > > > > > > > > > > > Ed
message
> > > success
but
> > > that
> > > > > > > example
> > > > > > > > > does
> > > > > > > > > > > not
> > > > > > > > > > > > > > work either.
method
> > with
> > > > > > ADT04,
> > > > > > > I
> > > > > > > > > > guess
> > > > > > > > > > > > the
> > > > > > > > > > > > > > Thanks,
> > > > > > > > > > > > > > Andy
Message 18 of 21
First I ran the code in debug mode. When it failed on that line, I checked
the registry for the class id.
Ed
news:E758975137C0C4C9CE34FF89F5B98D04@in.WebX.maYIadrTaRb...
> Andy
> work
16
15
> to
> > 16
> > Set adtApp =
> > Ed
> > > Andy
in
more
> > > help.
> > > > Sorry.
> > > > Ed
and
> > > tried
> > > > > Andy
> you
> > > > > using?
> > > > > > Ed
> > > > > > > Andy
> in
> > > the
> > > > > help
> > > > > > > > located at:
> ActiveX
Visual
> > > Basic
> > > > > to
> > > > > > > > HTH
> > > > > > > > Ed
> > > setting
> > > > > the
> > > > > > > ADT
> set
> > > the
> > > > > > > ADTdoc
> > > > > > > > to
> added
> > > the
> > > getinteface
> stuff.
> > > > > > Therefore
> > > > > > > > all
> > > instance
> > > > > of
> > > > > > > > acad.
> > work.
> > > > > > > provided
> > > > > > > > > you
> > referenced,
> > > > the
> > > > > > help
> > > > > > > > > topic
> > > > > > > > > > Ed
connect
> > to
> > > > > ADTapp
> > > > > > > not
> > > > > > > > > > ACAD
> > > > > > > > > > > app.
> > > > > > > > > > > so far i'm useing
> > > > > > luck(converted
> > > > > > > > to
> > > > > > > > > > vb6
> > > > > > > > > > > lang of course)
> the
> > > doc
> > > > > and
> > > > > > > > have
> > > > > > > > > > > Imports AutoCAD
> > > > > > > > > > > Imports AutoCAD_lib
> > > > > > > > > > > Imports AecXBase
> > > > > > > > > > > Imports AecXUIBase
> > > > > > > > > > > Imports AXDBLib
> > ByVal
> > > e
> > > > As
> > > > > > > > > > > Try
> > > > > > > > > > > MsgBox("Darn!")
> > > > > > > > > > > End Try
> > > > > > > > > > > End Sub
> > > > reference
> > > > > > the
> > that
> > > > > begin
> > > > > > > with
> > > > > > > > > > > "AEC".
> > > > > > > > > > > > Ed
message
> > > > externally
> > > > > > get
> > > > > > > > the
> > > > > > > > > > > wall
> > specific
> > > > > items.
> > > > > > > So
> > > > > > > > I
> > > > > > > > > > want
> > > > > > > > > > > > to
> > major
> > > > > > problem
> > > > > > > > I'll
program
> > > > > > > > > > > > > Thanks,
> > > > > > > > > > > > > Andy Elmore
> > > > > > > > > > > > > > Ed
> message
no
> > > > success
> but
> > > > that
> > > > > > > > example
> > > > > > > > > > does
> > > > > > > > > > > > not
> > > > > > > > > > > > > > > work either.
> method
> > > with
> > > > > > > ADT04,
> > > > > > > > I
> > > > > > > > > > > guess
> > > > > > > > > > > > > the
ADT3.3
> > > > > > > > > > > > > > > Thanks,
> > > > > > > > > > > > > > > Andy
Message 19 of 21
wivory
Gee you guys! Can you please *not* leave all the original text in the message every time you reply (especially if it contains a program listing). It makes it a pain to scroll through.
Wayne Ivory
IT Analyst Programmer
Wespine Industries Pty Ltd
Message 20 of 21
You gotta admit, though, that this was kind of neat-looking.
> > > > > > > > > > > > > > > Thanks,
> > > > > > > > > > > > > > > Andy
WEEEEEEEeeeeeeeeeeeee
”Boost
