I want to get the values of the parameters in a form and be able to change and when it does the values are sent to an Excel spreadsheet. Just that I can not.
sent him pictures, I hope you can help me.
This forum is traditionally for VBA toplc. So, if you are to do what you want with VBA, you are out of luck: there is no way for VBA to parameters/constarins introduced into AutoCAD since Acad2010.
You'll need to use ObjectARX C++ or .NET API for that.
Norman Yuan
Hi thanks for replying
Do not need to do it with VBA and have AutoCAD 2014
okay if I use ObjectARX C + + or. NET API, you will have an example that could help me please?
There is very few code samples one can find. This link would be helpful:
Norman Yuan
