For next slow why?
For next slow why?
For next slow why?
Why is the for next so slow?
I have a form with combobox filled up with 40 layers. The layers are from the layermanager.
The form has a command button too.
When I run this code. It's very slow to lock all layers.
Is there a solution for that?
Private Sub CommandButton1_Click()
On Error Resume Next    'handle exceptions inline
Dim objlayer As AcadLayer
'make the layer selected in the combobox current
ThisDrawing.ActiveLayer = ThisDrawing.Layers.Item(ComboBox1.Text)
For Each objlayer In ThisDrawing.Layers
    objlayer.LayerOn = False    'turn off all the layers
Next objlayer
Set objlayer = ThisDrawing.Layers.Item(ComboBox1.Text)
If objlayer Is Nothing Then
    MsgBox "layer does not exist"
    Exit Sub    'exit if layer not found
End If
objlayer.LayerOn = True 'turn on the desired layer
End Sub
Private Sub UserForm_Initialize()
 Dim layerColl As AcadLayers
  'fill combobox
 Set layerColl = ThisDrawing.Layers
 For Each objlayer In layerColl
    ComboBox1.AddItem objlayer.Name
 Next
 End Sub
 gr. Laszlo
Hallex
I repeat again, definelayer collection once then iterate through it, eg.: Option Explicit Private Sub CommandButton1_Click() On Error Resume Next 'handle exceptions inline Dim objlayers As AcadLayers Dim objlayer As AcadLayer Set objlayers = ThisDrawing.Layers 'make the layer selected in the combobox current ThisDrawing.ActiveLayer = objlayers.Item(ComboBox1.Text) For Each objlayer In objlayers objlayer.LayerOn = False 'turn off all the layers Next objlayer Set objlayer = objlayers.Item(ComboBox1.Text) If objlayer Is Nothing Then MsgBox "layer does not exist" Exit Sub 'exit if layer not found End If objlayer.LayerOn = True 'turn on the desired layer MsgBox "Done" End Sub Private Sub UserForm_Initialize() Dim layerColl As AcadLayers Dim objlayer As AcadLayer 'fill combobox Set layerColl = ThisDrawing.Layers For Each objlayer In layerColl ComboBox1.AddItem objlayer.Name Next End Sub
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
Thank you Hallex for patient.
Its still slow but maybe an other way than you mean.
The problem is the for...next:
objlayer.Lock = True 'lock all the layers
Next objlayer.
I have 40 layers.
Maybe I have to use the sendcommand  method for that?
ps. I changed "turn off" in "lock = true" tooSmiley Happy
Have a nice christmas!
Option Explicit
Next objlayer
End If
objlayer.Lock = False 'unlock the desired layer MsgBox "Done"
End Sub
'fill combobox
Next
End Sub
Hallex
Hi gr. Laszlo, I tested my code on drawing with about 125 layers for the test seems it's working very fast (something like less then 0.5 second) No problem if your code with SendCommand will do your job though Happy Holydays, ~'J'~
Alexander.Rivilis
Are you using AutoCAD x64?
64 Bit VBA Performance Issue
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
Yes I do.....
Alexander.Rivilis
@Anonymous wrote:
Yes I do.....
Then read: http://adndevblog.typepad.com/autocad/2012/05/64-bit-vba-performance-issue.html
Expert Elite Member
