Visual Basic Customization
Active Contributor
lanieuwe
Message 1 of 7 (333 Views)
For next slow why?
333 Views, 6 Replies
12-22-2012 10:28 AM
Why is the for next so slow?
I have a form with combobox filled up with 40 layers. The layers are from the layermanager.
The form has a command button too.
When I run this code. It's very slow to lock all layers.
Is there a solution for that?
Private Sub CommandButton1_Click()
On Error Resume Next    'handle exceptions inline
Dim objlayer As AcadLayer
'make the layer selected in the combobox current
ThisDrawing.ActiveLayer = ThisDrawing.Layers.Item(ComboBox1.Text)
For Each objlayer In ThisDrawing.Layers
    objlayer.LayerOn = False    'turn off all the layers
Next objlayer
Set objlayer = ThisDrawing.Layers.Item(ComboBox1.Text)
If objlayer Is Nothing Then
    MsgBox "layer does not exist"
    Exit Sub    'exit if layer not found
End If
objlayer.LayerOn = True 'turn on the desired layer
End Sub
Private Sub UserForm_Initialize()
 Dim layerColl As AcadLayers
  'fill combobox
 Set layerColl = ThisDrawing.Layers
 For Each objlayer In layerColl
    ComboBox1.AddItem objlayer.Name
 Next
 End Sub
 gr. Laszlo
Hallex
Message 2 of 7 (316 Views)
Re: For next slow why?
12-24-2012 02:03 PM in reply to: lanieuwe
I repeat again, definelayer collection once then iterate through it, eg.: Option Explicit Private Sub CommandButton1_Click() On Error Resume Next 'handle exceptions inline Dim objlayers As AcadLayers Dim objlayer As AcadLayer Set objlayers = ThisDrawing.Layers 'make the layer selected in the combobox current ThisDrawing.ActiveLayer = objlayers.Item(ComboBox1.Text) For Each objlayer In objlayers objlayer.LayerOn = False 'turn off all the layers Next objlayer Set objlayer = objlayers.Item(ComboBox1.Text) If objlayer Is Nothing Then MsgBox "layer does not exist" Exit Sub 'exit if layer not found End If objlayer.LayerOn = True 'turn on the desired layer MsgBox "Done" End Sub Private Sub UserForm_Initialize() Dim layerColl As AcadLayers Dim objlayer As AcadLayer 'fill combobox Set layerColl = ThisDrawing.Layers For Each objlayer In layerColl ComboBox1.AddItem objlayer.Name Next End Sub
Active Contributor
lanieuwe
Message 3 of 7 (306 Views)
12-24-2012 11:28 PM in reply to: Hallex
Thank you Hallex for patient.
Its still slow but maybe an other way than you mean.
The problem is the for...next:
objlayer.Lock = True 'lock all the layers
Next objlayer.
I have 40 layers.
Maybe I have to use the sendcommand  method for that?
ps. I changed "turn off" in "lock = true" too:smileyhappy:
Have a nice christmas!
Option Explicit
Next objlayer
End If
objlayer.Lock = False 'unlock the desired layer MsgBox "Done"
End Sub
'fill combobox
Next
End Sub
Hallex
Message 4 of 7 (300 Views)
12-24-2012 11:51 PM in reply to: lanieuwe
Hi gr. Laszlo, I tested my code on drawing with about 125 layers for the test seems it's working very fast (something like less then 0.5 second) No problem if your code with SendCommand will do your job though Happy Holydays, ~'J'~
Moderator
Alexander.Rivilis
Message 5 of 7 (278 Views)
12-28-2012 02:01 AM in reply to: lanieuwe
Are you using AutoCAD x64?
64 Bit VBA Performance Issue
Пожалуйста не забывайте про Утвердить в качестве решения! Утвердить в качестве решения и Give Kudos!Баллы
Please remember to Accept Solution! Accept as Solution and Give Kudos!Kudos
Active Contributor
lanieuwe
Message 6 of 7 (266 Views)
12-28-2012 12:00 PM in reply to: lanieuwe
Yes I do.....
Moderator
Alexander.Rivilis
Message 7 of 7 (262 Views)
12-28-2012 12:24 PM in reply to: lanieuwe
lanieuwe wrote:
Yes I do.....
Then read: http://adndevblog.typepad.com/autocad/2012/05/64-bit-vba-performance-issue.html
You are not logged in.
Ask the Community
