• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Visual Basic Customization
    Member
    First time automatisation (changing text) ACAD2012
    147 Views, 7 Replies
    01-07-2013 07:31 AM
    I'm trying to automate something that takes a lot of time at my company.
    We got a lot of P&ID drawings full of tags. I want to automate the modification of tags according to an excel table.
    I got something working but it's not reliable. It often doesn't work and it's very slow.
    Please comment on it. I'm no programmer besides some programming classes back in school.
    The form I call from.
    It's function is to let the user pick which P&ID's should be put in the modification loop.
    It's just a listbox (filenames), a textbox (for the file location) and a button.
    Private Sub CommandButton1_Click()
    Dim vtPid As Variant
    ReDim vtPid(0)
    Dim i As Integer, j As Integer
        j = 0
        For i = 0 To lstPid.ListCount - 1
            If lstPid.Selected(i) = True Then
                ReDim Preserve vtPid(j)
                vtPid(j) = lstPid.List(i)
                j = j + 1
            End If
        Next
    frmPidTag.Hide
    Call Modifie_PIDTag(vtPid, txtLocation.Text)
    End Sub
    The code is in my module.
    First I open the excel (table with 2 columns, old and new tag) and put the table in an array.
    The array is then used cycle through al entities.
    [b] I'm trying to change certain text located in the layer "instrumentation".[/b] It's just text strings, no blocks or anything.
    I'd like to use another method to get only the entities with possible matches but this seems to be the only reliable method. Only cycling textstrings would be better.
    Sub Modifie_PIDTag(ByVal vtPid As Variant, ByVal varLocation As String)
    ' Create the Excel object
    Dim oExcel As Excel.Application
    Dim oBook As Excel.Workbook
    Dim oSheet As Excel.Worksheet
    Dim aryPID()
    Dim LastRow As Integer
    Dim LastColumn As Integer
    ' Open existing workbook
    Set oExcel = CreateObject("Excel.Application")
    Set oBook = oExcel.Workbooks.Open(varLocation & "EXCEL\DrawingData.xlsx")
    'Set oExcel = New Excel.Application
    oExcel.Visible = False
    ' Open worksheet
    Set oSheet = oBook.Worksheets("PIDtag")
    oSheet.Activate
    ' Read Excel
    LastColumn = oSheet.Cells(1, oSheet.Columns.count).End(xlToLeft).Column
    LastRow = oSheet.Cells(oSheet.Rows.count, 1).End(xlUp).Row
    ReDim aryPID(1 To LastRow, 1 To LastColumn)
    aryPID = oSheet.Range(oSheet.Cells(1, 1), oSheet.Cells(LastRow, LastColumn))
    ' Cleanup
    oBook.Close
    oExcel.Quit
    Set oSheet = Nothing
    Set oBook = Nothing
    Set oExcel = Nothing
    ' Create the Autocad object
    On Error Resume Next
        Set objAcadApp = GetObject(, "AutoCAD.Application")
        If Err Then
            Err.Clear
            MsgBox ("AutoCAD is not running...")
        End
        Else
            Set objAcadDoc = objAcadApp.ActiveDocument
            Set objMspace = objAcadDoc.ModelSpace
        End If
    Dim Entity As AcadEntity
    Dim Doc As AcadDocument
    Dim saveloc As String
    For j = 0 To UBound(vtPid)
        'MsgBox vtPid(j)
        Set Doc = Documents.Open(varLocation & "TEMPLATE\" & vtPid(j) & ".dwg", False)
        If Err Then
        MsgBox "error"
        Err.Clear
        End
        Else
        AppActivate objAcadApp.Caption
        i = 0
        For Each Entity In Doc.ModelSpace
            If (Entity.Layer = "INSTRUMENTATION") And (Entity.EntityName = "AcDbAttributeDefinition") Then
                For i = LBound(aryPID) + 1 To UBound(aryPID)
                    If Entity.TagString = CStr(aryPID(i, 1)) Then
                        Entity.TagString = CStr(aryPID(i, 2))
                    End If
                Next
            End If
        Next
    saveloc = varLocation & "\DWG\" & vtPid(j) & "-new.dwg" ThisDrawing.SaveAs saveloc ThisDrawing.Close End If Next End Sub
    The get/create autocad object may seem out of place there but it was the only way to solve an error.
    Calling the subroutine from a form gave me automation errors. I think it was a focus/activation problem. Anyway, this seems to solve it.
    Thanks!
    Please use plain text.
    Member
    Re: First time automatisation (changing text) ACAD2012
    01-08-2013 02:56 AM in reply to: dee2me
    Ok, I created a selectionset to lessen the amount of entities I need to loop through.
       Dim sset As AcadSelectionSet
       Set sset = ThisDrawing.SelectionSets.Add("FilterSet1")
       Dim filterType As Variant
       Dim filterData As Variant
       Dim p1(0 To 2) As Double
       Dim p2(0 To 2) As Double
       Dim grpCode(0) As Integer
       grpCode(0) = 8
       filterType = grpCode
       Dim grpValue(0) As Variant
       grpValue(0) = "INSTRUMENTATION"
       filterData = grpValue
       sset.Select acSelectionSetAll, p1, p2, filterType, filterData
       For Each Entity In sset
            If Entity.EntityName = "AcDbAttributeDefinition" Then
                    End If
                Next
            End If
        Next
    This doesn't seem to help.
    Autocad still does what it wants. Sometimes it executes, sometimes it doesn't.
    It's like VBA is executing really fast and autocad can't keep up.
    Distinguished Contributor
    truss_85
    01-08-2013 06:34 AM in reply to: dee2me
    "It's like VBA is executing really fast and autocad can't keep up." I am affraid, that is not possible. VBA does not execute anything fast. The real reaseon is VBA did not catch Autocad may be.
    Can I ask you which operation system you have? If it is 64 bit vba does not support properly. There is something like VBA 64 bit server it delays everything. May be that is the reason it too slow working. Microsoft did not support VBA any more. Visual Studio suggested for any furter application.
    Member
    01-08-2013 11:37 PM in reply to: dee2me
    Windows 7 64b.
    Visual studio would mean I'd have to create standalone apps.
    I just want to automate some cheap tricks. I do it all the time in Excel/Word/Access
    Any other language I can use that is supported? It can't be any more basic as VB.
    truss_85
    01-09-2013 12:17 AM in reply to: dee2me
    It did not mean standalone application. May be I missunderstood microsoft does not support Visual Basic for Application in other terms VBA. You can still use visual basic language but in a different platform.  In VBA you create .dvb file, in vb.net you can create Visual Studio has also support visual basic. You can use express edition for both office and cad documents or may be lisp will do it.
    truss_85
    01-09-2013 01:33 AM in reply to: dee2me
    For further information  Check this
    Member
    01-09-2013 08:19 AM in reply to: truss_85
    I changed EntityName to ObjectName and moved everything to Access.
    It works fast enough in Access.
    Go figure.
    truss_85
    01-09-2013 08:32 AM in reply to: dee2me
    Also you can modify your selection set type of object "0" group code and attribute def.
    It possibly run faster
