Hi, try this. Certanly not the best way to do it but it works...
Sub test()
ExportLines ("LAYERNAME")
End Sub
Function ExportLines(layerName As String)
Dim fType() As Integer, fData()
Dim sset As AcadSelectionSet
Dim acObject As AcadObject
Dim i As Integer
'filename to export to
Dim expFilename As String
expFilename = "d:\temp\autocad\ExportLines.txt"
'get the next free file identifier
Dim fnum As Variant
fnum = FreeFile()
'open the filename
Open expFilename For Output As fnum
On Error Resume Next
'try to create a new selectionset
'if it exists, delete it and recreate a new one
Set sset = thisdrawing.SelectionSets("sset")
If Err Then Set sset = thisdrawing.SelectionSets.Add("sset")
'if it exists, erase it's content
sset.Clear
'filter lines and polyline in a given layer
ReDim fType(7), fData(7)
fType(0) = -4: fData(0) = "<and"
fType(1) = -4: fData(1) = "<or"
fType(2) = 0: fData(2) = "LINE"
fType(3) = 0: fData(3) = "LWPOLYLINE"
fType(4) = -4: fData(4) = "or>"
fType(5) = 8: fData(5) = layerName
fType(6) = 67: fData(6) = "0" 'modelspace=0 paperspace=1
fType(7) = -4: fData(7) = "and>"
On Error GoTo Crashed
'get selectionset
sset.Select acSelectionSetAll, , , fType, fData
'prompt how many objects were found
thisdrawing.Utility.Prompt (vbCrLf & "Exporting " & sset.Count & " Lines and Polylines")
'go throu all objects in selectionset
Dim objLine As AcadLine, objPolyline As AcadLWPolyline
For Each acObject In sset
If TypeName(acObject) = "IAcadLine2" Then
Set objLine = acObject
'write to file
Write #fnum, "X=" & objLine.StartPoint(0) & ", " & _
"Y=" & objLine.StartPoint(1) & ", " & "Z=" & objLine.StartPoint(2)
Else
Set objPolyline = acObject
Dim plCoord As Integer
'build string with Polyline coordinates to export
Dim expCoordinates As String
expCoordinates = ""
'print points
For i = 0 To UBound(objPolyline.Coordinates) Step 2
expCoordinates = expCoordinates & "X=" & objPolyline.Coordinates(i) & ", " & _
"Y=" & objPolyline.Coordinates(i + 1) & ", "
Next i
'write to file
Write #fnum, expCoordinates & "Z=" & objPolyline.Elevation & ", Closed=" & objPolyline.Closed
End If
Next acObject
Crashed:
'close file
Close #fnum
'clear selectionset
sset.Clear
End Function
