Show only
Search instead for
Actually it determines the name of the variable to read.
"Dale Levesque" wrote in message
news:5064997@discussion.autodesk.com...
Does anyone know a way to read a formula as text in a field and then run it
on some variable? It's similar to the following Lisp sample.
In lisp the following would use the variable panel_type to determine the
name of the variable to create.
Did you search this group ?
I know I read the same question several months back in this group. I searched and searched but did not find it.
If you find the solution would you please post it, I would like to add this to my bag of tricks.
