I couldnt find this on the internet so i figured to write it and post it here:
Private Sub BlockAll() 'define variables Dim objSS As AcadSelectionSet Dim objBlock As AcadBlock Dim objBRef As AcadBlockReference Dim strName As String Dim objSourceEnts() As Object Dim varDestEnts As Variant Dim intI As Integer Dim dblOrigin(2) As Double 'make selection set include all objects / entities On Error Resume Next ThisDrawing.SelectionSets.Item("TempSSet").Delete Set objSS = ThisDrawing.SelectionSets.Add("TempSSet") objSS.Select acSelectionSetAll 'set the user input variable and origin strName = "Block1" 'you can use .getstring to ask user dblOrigin(0) = 0: dblOrigin(1) = 0: dblOrigin(2) = 0 'create the 'empty' block using the given block name Set objBlock = ThisDrawing.Blocks.Add(dblOrigin, strName) 'put selected entities into an array for CopyObjects ReDim objSourceEnts(objSS.Count - 1) For intI = 0 To objSS.Count - 1 Set objSourceEnts(intI) = objSS(intI) Next 'copy selected entities into the block varDestEnts = ThisDrawing.CopyObjects(objSourceEnts, objBlock) 'erase original entities, insert block, and delete array selection set objSS.Erase Set objBRef = ThisDrawing.ModelSpace.InsertBlock(dblOrigin, strName, 1, 1, 1, 0, True) objSS.Delete 'completion message MsgBox "Done." End Sub
Hope this helps, If you have any suggestions to inprove this code please post below...
Hello Noel
thanks for the Idea i want to request u that can u modify or write a new program according to my requirement
that i need a USERFORM in VBA to get points Coordinates and Make the intersection As Block in autocad
Thanks in Advance
