I'm working with AutoCAD 2014 VBA.
I can not find the ocx of the Microsoft common dialog control in additional controls, while there is in the references?
how come? does anyone have any idea?
That is because that you are very likely using 64-bit AutoCAD 2014 (who does not?).
Since AutoCAD 2014, the VBA used for 64-bit AutoCAD is also 64-bit. This is different for previous version of AutoCAD: VBA remains as 32-bit process running outside AutoCAD process, if the AutoCAD is 64-bit.
While with 64-bit VBA now runs in the same procesds of 64-bit AutoCAD, the infanous "slowness" of VBA (32-bit) for previous 64-bit AutoCAD should go away, the practical usage of 64-bit VBA is a bit limited to existing VBA application, if one want to update the existing VBA code to AutoCAD 2014 64-bit, espcially when the VBA apps have a lot of UI (user forms) that uses 32-bit controls: most commonly used 32-bit control components simply do not have 64-bit version replacement.
So, if you want to run VBA in AutoCAD 2014 64-bit, you are limited to the components built into VBA (MS Forms controls). Thus, there is no CommonDialogControl.
You'll need to either use AutoCAD 2014 32-bit,or you have to find needed 64-bit components (very hard). IN the case of CommandDialog, you could directly call Windows API (if you know how to).
If I had UI intensive application requirement, I'd not try 64-bit VBA, in the case of AutoCAD 2014.
Norman Yuan
In 2014 will not work even the 32-bit API
I had to use an Excel object: Filedialog
