VBA
Discuss AutoCAD ActiveX and VBA (Visual Basic for Applications) questions here.
Change all the attributes color
3 REPLIES 3
mohandis2
579 Views, 3 Replies
My drawing has blocks nested into blacks nested into blacks nested into blacks and so on, and every block may or may not have attributes, how can I change all the attributes color? Any help please?
3 REPLIES 3
truss_85
in reply to: mohandis2
You mean inside the vba or outside ?
mohandis2
In vba,
truss_85
Here it is what you want:
Public Sub block_nest()
Dim objBlock As AcadBlockReference
Dim objBlock_objEnt As AcadBlockReference
Dim objBlk As AcadBlock
Dim objBlkRef As AcadBlockReference
Dim objEnt As AcadEntity
Dim var_atts As Variant
For Each objBlk In ThisDrawing.Blocks
    For Each objEnt In objBlk
        If TypeOf objEnt Is AcadBlockReference Then
            Set objBlock_objEnt = objEnt
            var_atts = objBlock_objEnt.GetAttributes
            For j = 0 To UBound(var_atts)
                var_atts(j).color = acRed
            Next
        End If
    Next
Next
End Sub
”Boost
