VBA
Discuss AutoCAD ActiveX and VBA (Visual Basic for Applications) questions here.
C# connection to Autocad LT 2014
1 REPLY 1
1202 Views, 1 Reply
Hi all!
I have a c# connection, this code run fine in Autocad 2014. The final purpose of my program is create a .dwg file and add labels in mentioned .dwg file but not work in Autocad LT 2014 .
My code:
try
// Upon creation, attempt to retrieve running instance
m_AcadApp = (AcadApplication)Marshal.GetActiveObject("AutoCAD.Application.19");
m_bAcadInit = true;
catch
try
// Create an instance
m_AcadApp = new AcadApplication();
m_bAcadInit = true;
} catch(Exception ex)
MessageBox.Show("An error occurred trying to open the AutoCAD.", "Attention", MessageBoxButtons.OK, MessageBoxIcon.Information);
//In LT version this message appears
Is possible open Autocad LT 2014 with my code or similar code?
Thank you very much.
Tags (1)
1 REPLY 1
Alfred.NESWADBA
you might get start AutoCAD LT using e.g. Process.Start, but at least AutoCAD LT has no built in API, so there is also no COM-interface that can be used like you did with AutoCAD.
That is one of the major reasons why LT is much cheaper than the full version.
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
”Boost
