VBA
Discuss AutoCAD ActiveX and VBA (Visual Basic for Applications) questions here.
Autocad 2014 / VB.NET ModelSpace error
1 REPLY 1
rafal.watroba
914 Views, 1 Reply
The problem seems to be elementary, but I can't find solution.
After migratting my program (VB.NET using COM) to AutoCAD 2014 (from 2012) I get an error when access Document.ModelSpace (Element not found. (Exception from HRESULT: 0x8002802B (TYPE_E_ELEMENTNOTFOUND)).
I started new, clear solution, added references to:
Autodesk.AutoCAD.Interop.dll
Autodesk.AutoCAD.Interop.Common.dll
I wrote this simple code:
    Private Sub Button1_Click(sender As System.Object, e As System.EventArgs) Handles Button1.Click
        Dim acad As Autodesk.AutoCAD.Interop.AcadApplication
        acad = CType(Marshal.GetActiveObject("AutoCAD.Application"), Autodesk.AutoCAD.Interop.AcadApplication)
        Dim d As Autodesk.AutoCAD.Interop.AcadDocument = acad.ActiveDocument
        Dim m As Autodesk.AutoCAD.Interop.Common.AcadModelSpace = d.ModelSpace
    End Sub
I still get an error at line "Dim m As Autodesk.AutoCAD.Interop.Common.AcadModelSpace = d.ModelSpace".
1 REPLY 1
I found solution.
I needed to change active platform from x86 to AnyCPU.
I don't know why my vb.net started new project with x86 platform.
”Boost
