VBA
Discuss AutoCAD ActiveX and VBA (Visual Basic for Applications) questions here.
Add an entity to a block
8 REPLIES 8
Message 1 of 9
309 Views, 8 Replies
I am struggling to add an entity to a block definition. I have the following
code but the circle does not get added:
Sub TTest()
Dim blkMyBlock As AcadBlock
Dim dCenter(0 To 2) As Double
Dim dRadius As Double
dCenter(0) = 0#: dCenter(1) = 0#: dCenter(2) = 0#
dRadius = 100#
For Each blkMyBlock In ThisDrawing.Blocks
If blkMyBlock.Name = "TEST" Then
Set blkMyBlock = blkMyBlock.AddCircle(dCenter, dRadius)
End If
Next blkMyBlock
End Sub
Any assistance will be appreciated.
Regards
Sean Bartleet
8 REPLIES 8
Message 2 of 9
You need to return the AddCircle method to a BlockReference object. Also
consider setting the BlockDef via
Set blkMyBlock = ThisDrawing.Blocks.item("TEST') rather than iterating
through all block def's.
John Goodfellow
irtfnm
use john at goodfellowassoc dot com
"Sean Bartleet" wrote in message
news:BB699F04BDCCBF74182F50F8776C0F04@in.WebX.maYIadrTaRb...
> Hi,
following
> Sub TTest()
> dRadius = 100#
> End If
> Next blkMyBlock
> End Sub
> Regards
> Sean Bartleet
Message 3 of 9
Thanks for the top to reference the block directly.
But, I am now confused. What I want to do is add a circle to the block
definition and update all instances of that block in the drawing.
Help tells me that a "BlockRef object" is "An instance of a block definition
inserted into a drawing." I interpret this to be a reference to the block
definition. Help also does not list an add method to this class.
Help tells me that a "Block object" is "A block definition containing a name
and a set of objects" or "A simple block is a collection of objects you can
associate together to form a single object, or block definition." Which had
an add method.
Am I wrong in saying that I need to use the add method to add a circle to
the block definition?
The following code gives me an type mismatch error on the "Set blkMyBlock =
blkMyBlock.AddCircle(dCenter, dRadius)" line.
Sub Test1()
dRadius = 100#
Set blkMyBlock = ThisDrawing.Blocks.Item("TEST")
End Sub
Any suggestions?
Sean Bartleet
"John Goodfellow" wrote in message
news:EAA39B6B6B2C3BF9622D875DCBCB3FAA@in.WebX.maYIadrTaRb...
> John Goodfellow
> irtfnm
Message 4 of 9
Sean,
Try this
Sub Test1()
dRadius = 100#
blkMyBlock.AddCircle dCenter, dRadius
ThisDrawing.Regen acActiveViewport
Set blkMyBlock = Nothing
End Sub
hth
Mark
news:398939D06D8854BE93360B5954840704@in.WebX.maYIadrTaRb...
> Hi,
Message 5 of 9
Thanks, this worked great.
Any idea as to why the syntax is is not shown in the help like that?
What is the difference between
and
How am I supposed to know when to use what syntax?
Thanks again for the help.
Sean
"Mark Propst" wrote in message
news:740A1B93D9964EFC141F7018D9A1F05E@in.WebX.maYIadrTaRb...
> Sean,
> Try this
> Sub Test1()
> dRadius = 100#
> End Sub
> hth
> Mark
Message 6 of 9
news:2FDB3F393C5C8C503B30877B7D0D3054@in.WebX.maYIadrTaRb...
> Hi,
well, call it paranoia but after trying to learn programming on my own for
more than a few years now, (and before learning of these ngs which are a god
send to anyone who wants to learn), I have come to the conclusion from all
the typos, unavailable, unclear or incomplete explanations, let alone the
downright wrong explanations, that help files were only created to deter the
slothful, lazy, and anyone with less than a 5000 iq from ever learning to
program...:-)~
(but maybe it's just me!)
> and
the "Set" keyword?directive? (if that's the right term - probably not) is a
'command' that creates an object, an instance of a class. It allocates a
memory location and then stores the object you create in the symbol you
provide it, in your case blkMyBlock. Once you have that object created in
memory you have all the methods and properties which that object possesses
at your command. For the duration of the life of your object(scope) you can
manipulate, read or write, the various properties and exercise the methods
belonging to that object. You don't need the "Set" in order to utilize any
of those 'attributes' of the object. The "Set" is only needed to create the
object in the first place, and then at the end of your program, in most
cases you want to Set blkMyBlock = Nothing, in order to free up the memory
location allocated in your original Set blkMyBlock = "create or get block
object." and allow that memory slot to be used by ongoing operations
(prevent memory 'leaks')
I'm far from an expert on this and hopefully some one who really knows what
they're talking about can correct *my* inaccuracies and deficiencies of
explanation - lest I become known as little better than an errant help file!
have fun
Mark
Message 7 of 9
Sean,
I don't blame you (and Mark) for being confused about this, but I'll try to explain.
Methods (such as AddCircle) typically both *do* something (eg add a circle) and *return* something (eg the newly added circle object). If you need the returned object for further processing then the left side of the statement needs to assign the returned object to a variable.
Set MyNewLine = ThisDrawing.ModelSpace.AddLine(pt1, pt2)
If you don't need the returned object then you can omit the assignment part of the statement. The parentheses around the arguments are also omitted in this circumstance.
ThisDrawing.ModelSpace.AddLine pt1, pt2
Now in your case you are using an AddCircle method, and the Help says that the return value from this method is "The newly created Circle object". If you are going to assign this object to a variable it needs to be of type AcadCircle, whereas you were trying to assign it to a variable of type AcadBlock (ie blkMyBlock). It would seem from the context that you only wanted to *do* the method and didn't need the *return* value which is why Mark's solution worked for you.
Hope this helps.
Regards
Wayne Ivory
IT Analyst Programmer
Wespine Industries Pty Ltd
Message 8 of 9
Thank you for fixing my botched misinformation.
Man was I off on that one!
"wivory" wrote in message
news:f14c1c3.5@WebX.maYIadrTaRb...
> Sean,
to explain.
> Hope this helps.
> Regards
> Wayne Ivory
Message 9 of 9
Thanks Mark for the initial explanation and Wayne for the clarification.
This has helped a lot.
Regards.
Sean
> Sean,
to explain.
> Hope this helps.
> Regards
> Wayne Ivory
”Boost
